Wood Working DIY Mahogany Counter Tops Out of Plywood!
Introduction: Wood Working DIY Mahogany Counter Tops Out of Plywood!
This is a tutorial on how I built the mahogany counter tops in the little house out of plywood. I was in a real pickle when it came to what I wanted to do with the counters in the little house. Normally I probably would have just run to Menards (or Lowes or Home Depot) and purchased stock laminate counter tops that they have on hand. But because I chose to put cabinets back to back I had a span of 48×60 inches to cover so if we wanted laminate counter tops they would have to be custom ordered and thus: too much a splurge for this little house. A big part of me wanted to just use barnwood like I did for the kitchen backsplash but I knew my mom would hate that and if she ever lived here she deserves the flattest smoothest counter that she could ever want. So, I was in a pickle.
After I built the upper kitchen cabinets I headed to my local lumber yard to purchase cabinet doors and they didn’t have smooth pine plywood. Like, what?! Who doesn’t have sanded plywood made of pine?!?!?! All they had (in at least 3/4 of an inch) was plywood with a mahogany veneer so, I sucked it up, figured: “How bad could it be?” And brought them home. Well seconds after bringing them in the door I knew I was already unhappy. Because we were leaving the pine trim as it was (plus a couple of coats of poly acrylic) I did the same with the upper kitchen cabinets to keep the whole house looking cohesive. And then I slapped those red mahogany cabinet doors on them and it just made me shudder.
I put up the barn wood back splash behind the sink crossing my fingers that the multiple different shades of wood and patina would help those mahogany doors and pine cabinets clash a little less horribly. It did help and everyone else said it all looked great but, of course, they still bothered me. And then the light bulb went off. See, we have quite the clash going on anyway because of the brand new white stock base cabinets we installed in the kitchen. (You can check em out here on the Menard’s website.) Even after trimming around the bottom edge of the cabinets (the toe kick) in the same pine I used to build the uppers there was still a feeling of hard core difference between them. So, I needed a flat surface for a counter top that we could build ourselves: why not use the same mahogany plywood I had used for the upper cabinet doors?!
Step 1: Getting and Cutting the Plywood
The idea was born for mahogany counter tops and Joe (my very helpful husband/hero) helped me one weekend go pick up a full sheet, bring it back and cut it to size using a skill saw. One sheet managed to (just barely) provide us with the big L shaped piece and the small piece for the kitchen sink. (Notice how we used blue tape to cover the plywood so it wouldn’t be scratched by the skill saw but in the end we found that this plywood is so darned hard and our skill saw so smooth that we actually didn’t need to tape it but, better safe then sorry!) This is not really a one-man job, could one guy have got this all done with the right set of saw horses positioned smartly? Yes! But the two of us made this a much easier task: one person holding with the plywood half on the cabinets and the other person cutting: which is why I have no pictures during the cutting process because my hands were full. I used 2x4s run across the tops of the cabinets to provide support but to also pick it up so I could trim out the outside and make it look much thicker then it was. (I also wanted to cover that ugly plywood edge.)
Step 2: Securing It in Place
I tacked it down with brad nails and liquid nails NOTE: I used a lot of liquid nails and only a few very strategically placed brads in the top of the counter top, I knew the glue, the weight of the plywood itself and the trim would hold it in place. I trimmed it out in barn wood also using brad nails and liquid nails and sanded it using my DeWalt orbital sander. Another note: when I say I sanded it I mean I really just VERY CAREFULLY sanded the barn wood, this plywood is veneer and could take almost no sanding whatsoever before I went through the mahogany top. It was difficult because I really couldn’t hit it at all even where it met the barn wood trim. I filled in the nail holes and any gaps with mahogany wood filler and carefully hand sanded the mahogany top before wiping it all down with a damp paper towel.
From there I put on five separate coats of poly acrylic. Why did I choose a water based poly acrylic? Well, honestly, I chose it for the same reason everyone ends up choosing the water based: It dries faster by literally hours, it doesn’t yellow and its not nearly so toxic to the person who is applying it. I really ALMOST headed for the really hardcore polyurethane (the type they make specifically for floors) but I’ve finally got enough experience under my belt that I knew that the oil based would only perform a little bit better and thus: not worth the cost or the time to me.
So, I went with a semi gloss poly acrylic by Minwax and did five coats over a few days. I hand sanded after the first two coats with 220 grit sand paper and right before the last coat. (I have not installed the sink yet, just set it in place for pictures but when I do I will also caulk between the countertop and the backsplash)
Step 3: Completion
You can see I also built a little “backer” to cover up the ugly back of the stove using 2x2s and barn wood that also got the sanding and poly treatment. It is wide enough to be used for spices, salt and pepper etc. I think it helped tie the the sink area to this area nicely. Not to mention those adorable wood knobs! Aren’t they just precious? They’re like little wood buttons! I purchased them from Amazon for only $8 for 20 of them!
All in I am extremely happy with how the counter tops turned out. They’re smooth, you can spray them with water and wipe them down etc. Of course, you will never be able to put a boiling hot pan on them but, really, there are few counter top surfaces you can actually do that with anyway. So now, how do I feel about the clash of the uppers in pine and their red mahogany doors? I feel this counter top tied the whole kitchen together and I can finally say that YES, I am happy with it!
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Paper Contest 2018
      Paper Contest 2018
    Great Job, I really like the placement of the range.
