Introduction: Wood Lighting
Wood lighting
Step 1: What Kind of Tools Do You Need?
One piece wood which has 40 cm length. ( apple tree )
· One piece Plexy tube which has 30 cm length and 4 cm width.
· Glue for wood.
· Cellulose based varnish
· One piece brush which is 5 cm
· Led light emitting diod which is 200 cm ( yellow )
· Led light emitting diod setting adaptor
· Workplace tools.
o Blade of a band saw
o Hammer
o Nail
o Driller
o Sanding machine
Step 2: How to Begin?
Wooden is sliced by blade of s band saw with 2 cm length.
Step 3:
After that, all slices’ center point is cut by driller.
Step 4:
Slices, which are cut from center point, are rubbed with emery to have rubbed surface.
Step 5:
Glue for wood is applied to prevent fracture and waited to dry for a day.
Step 6: Japanning to Wooden Slices
Wooden slices are varnishing with the brush and after that wooden slices are dried. This process is done 2 or 3 times.
Step 7: Plexy Tube Grinding
Plexy tube is cut by blade of a band saw and it has 40 cm length. After that plexy tube has matt surface with machine
Step 8: Final Step
All slices are positioned on the plexy tube according to layout. ( There is no need to any glue. Dry wood is tighten up and prevent to move. ) After, led light emitting diod, which is 200 cm, is placed into tube and illumination is done.
