Wood Vise Quick Release Fix
Introduction: Wood Vise Quick Release Fix
I was given a wood working vise that was new unused but missing the return spring for the quick release handle.
How hard can it be to buy a replacement part? Very hard it turns out, I could not get a replacement spring anywhere.
I thought I could use the vise as is but if I am winding the handle with one hand and holding the work piece with the other I need another hand to hold the quick release lever over so that the vise will tighten, a fix needed to be found!
Video shows a vise not opening and closing properly because of the missing spring.
Step 1: The Design
The design was pretty much done on the band saw, I cut a piece of 18mm plywood out to fit around the narrowed part of the lead screw boss, radiusing both sides to fit snugly around the shaft.
This was followed by cutting out a semicircle offset from the first cut to create a cam.
I then put it in place on the vise to work out where the holding notch needed to be.
Step 2: Clamp
The clamp is simple enough, a piece of the metal strapping that is used to strap an item to a pallet, bent in a semicircle to fit the handle shaft and a flat with a hole drilled in it to join it to the wooden block.
This is held in place with a round head wood screw.
Step 3: All Fitted and Tested.
This device works in two ways, if left to its own devices when the handle is turned to do up the vice the cam turns under and holds the quick release handle out far enough to engage the nut on the lead screw and the vise closes and clamps.
Undoing the handle will release the vice jaws and the cam will turn away from the quick release handle allowing the quick release to operate.
The second way is to manually turn the cam until the end of the quick release handle drops onto the locking notch. now which ever way the handle is turned the nut on the lead screw will not be disengaged and the vise will open and close with the screw.
The video shows it in action.
I hope this instructable is of use to others as this is not the first vise with broken/missing spring I have come across.
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    That design has potential to be superior to the original, well done. I too save pallet strapping, only the plastic variety, it makes great pipe hangers and especially cable clamps- the home centers are happy to see it go.
    Thanks for the comment! The metal band strapping is great for shims as well, a very versatile bit of free material :) I do keep a certain amount of the plastic strapping but I find it is a bit awkward to store in long pieces.
