Step 5Making the propellors & put it together
For the propellors we use 2 ice cream sticks. If the ones you have are too big for your airplane, just saw off a piece and sand the edge untill it's rounded.
I also cut out half of the sticks in the middle where they meet, so they fall into eachother. This isn't necessary but makes it look a little cleaner. Glue the 2 sticks onto eachother in the middle.
To make the nose cone, sand the larger round stick untill you get the desired cone shape. Then saw this off the stick. (if you reverse these steps it might be difficult to sand the piece)
Drill a hole into the body and the nose cone, the same size as your axle will be.
Drill a slightly larger hole in the middle of the propellors, so that it spins smoothly around the axle.
Cut your axle to size, so that it fits into the body and the nose cone, and leave enough space so that the propellors can spin freely.
Glue your axle into the body of your airplane, and wait for the glue to dry. Then put on the propellors and glue on the nose cone.
Add Comment
