Wooden Book Cover
Introduction: Wooden Book Cover
So recently my friend has gotten me a notebook with a cover that wasn't as appealing to me. Instead of being a jerk and getting a new book, I decided to create a new book cover for the book. After thinking about various book covers, I decided that the best course of action would be to make a book cover out of wood.
Materials needed:
- 1/8 inch sheet plywood
- old notebook (could buy new, but who wants to spend money?)
- glue (preferably craft glue)
- laser cutter
-computer (for the design and cutting)
-heat gun
Step 1: Design
First i gutted pages from the book cover. Then I hopped onto libre office draw (one of the many laser cutting softwares I'm comfortable with) and I drew living hinges.
Living hinges are little slits in wood or cardboard that allow it to bend without the use of adding actual hinges. I created different test hinges to see which best fit the book pages.
Step 2: More Laser Cutting + Bending Cover
After I found the best hinge (not shown), I stacked them to the hight of the original book cover and added rectangles for the front and back of the cover. With the file made, I sent them to the laser cutter to cut.
After the cover was cut, I noticed that it naturally stayed in an open position. To get it to close naturally, I soaked the hinge in water for three minutes. Because I didn't want to bend the front and back cover as well, I applied wet towels over the hinge itself. Once three minutes passed, I bent the book to where it stayed closed and applied heat to it via heat gun so that it stayed in that position
Step 3: Fitting and Glueing
Now all thats left is to glue the cover to the book. Being that this was the first ever book cover I made, I didn't know the best way to glue it. I do plan to learn a better method and put it on an updated instructable.
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
    • Pocket-Sized Contest
    And thank you for the recomendation dankozi713
    From what I know, the hinge works best when you laser cut along the wood gradient for it naturally bends that way. However I know that by wetting the hinge in that one step above, It reduced the chance of it snapping while bent. So for now, it should survive for a long while. Laser Cutting it does make it weaker, but not too weak that it will always break, and it also depends on the hinge pattern/ how think you make each bend line.
    You might be able to get an idea of how to glue it from Jimmy Diresta's YouTube vid on book binding. That dude rules!!
    Very nice. How do you think the hinge will hold up to years of opening and closing? Does laser cutting a hinge in this way eventually wear down the hinge?
