3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wooden Burr Puzzles
Wooden Burr Puzzles
For a full writeup go here: http://francisshanahan.com/detail.aspx?cid=697
I came across IBM's website on burr puzzles [LINK and decided to make one.
"Burr puzzles are interlocking puzzles known in Europe and Asia since at least the 18th century. Traditionally they are made from wood....and require special wood so that the pieces do not change shape too much in changing temperature and humidity."
To make these, I ripped a thin piece of oak to 3/4" square using my table saw. The pieces are 2 1/4" long so your piece needs to be about 18" long to get 6 pieces. I actually cut 7 in case I screwed up. I later made another with Cherry and found it a much easier wood to work with.
I first picked "David Winkler's favorite level 5 burr" [LINKLINK]. This is a "notchable" burr meaning you can construct it entirely by notching the pieces. I used a bit of red-oak I had laying around. This burr is 6 units long, 2 wide. The unit size in my case is 3/8" which I found a good size. The design in this case is a "5.4" meaning there are 5 moves required to remove the first piece, then 4 to remove the 2nd.
Just print out the pieces you want to cut and bring that sheet to the workshop. For notched pieces your best tool is a bandsaw and some sandpaper for fit.
Each "notch" is 3/8" of an inch. There are six notches per piece.
The IBM site has other "general" pieces which have notches that only go half-way, for these I used a mortising chisel.
These pieces are small. The slower you go, the better they'll fit. Take your time, have fun and watch your fingers.
5 comments
Jan 27, 2011. 9:15 AMCaboose98 says:
What would be an easy way to get in the notches after you have made the cuts for say the bottomw left piece. The bottom left cut, i would make the cuts on teh left and right side of the opening, then how would i cut that chunk out?
Mar 27, 2010. 10:29 AMNicola Tesla says:
my brother has that!
Aug 12, 2008. 5:01 PMheavy.metal.nguyen says:
I never could do that puzzle. I have a set of four with that one in it, all the others I can do, but not this one.
Aug 13, 2008. 6:28 PMheavy.metal.nguyen says:
Well I have the instructions, but they are very hard to read because the pictures are so small.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:FrancisShanahan
