Introduction: Wooden Carcassonne Board Game.
Picture of Wooden Carcassonne Board Game.
I have recently become addicted to Carcassonne on the iPad and iPhone, so i decided i wanted to make my own version out of wood.
i like making wooden board games so i thought i would give this a go.
Step 1: Tools and Materials.
Picture of Tools and Materials.
Tools.
I used:
A laser cutter.
A computer will Illustrator (to create files for the laser cutter.)
Rubber (eraser for the Americans)
Sand paper.
Materials.
This ply wood (1.6mm)
acrylic plastic 5mm
coloured acrylic plastic (3mm)
acrylic solvent glue.
Step 2: Planning and Drawing.
Picture of Planning and Drawing.
As i had purchased the game on the ipad i used it to play the game and take a few screen shots while playing making sure to capture all the tiles at least once.
There are 71 tiles in the game. This meant that there were multiples of some of the tiles so i didn't have to draw all 71 tiles.
once i had the screen shots i imported them into Illustrator and scaled them to a size i felt would be good for the individual tiles.
once scaled i drew over the tiles in illustrator ready for them to be cut out on the laser cutter.
Step 3: Etching, Cutting and Cleaning the Wooden Parts.
Picture of Etching, Cutting and Cleaning the Wooden Parts.
Once i had all the tiles drawn up and arranged to match the piece of wood that i had I set the laser off doing its thing.
once it finished i checked i had all the parts and that there were no errors. (it was all good)
when everything had finished cutting i had to clean the edges up. (not that they were poorly cut its that the charring from the laser cutter makes it smudgy when you handle the pieces, which makes it a useless board game) i used the rubber (eraser) to clean the edges of the playing pieces. this took a long time but it makes them more usable.
one could use sandpaper to do the cleaning but the sandpaper is a destructive process and if you slip you could ruin a playing piece where as using the soft rubber (eraser) will not cause any damage when you slip or make a mistake.
Step 4: Making the Playing Pieces.
Picture of Making the Playing Pieces.
Once the wooden parts were cut i moved onto the little meeple.
There are 7 meeps per set and i made 7 sets.
I drew out a meep and cut him out 7 times per different colour of plastic, i used red, orange, blue, yellow, white, green and pink.
There are 7 per player but i needed one more for the score counting so i cut out one more meep slightly larger for the counting system.
once i had cut them out of 3mm acrylic i realised that they needed to be slightly thicker so they can stand up, so i then cut out enough clear meeple to back each counter to give them the thickness.
When i finished all the meeple i made them some little boxes/cases to hold each players set of meeple.
Step 5: Making a Box.
Picture of Making a Box.
i really wanted to make a wooden box or find a nice old box for it and i stil might but for now ive made a nice thick acrylic slide lid box that holds all the parts perfectly.
i made a simple rectangle box base with a slightly bigger box top (bigger by 5mm in each dimension) so it would slide over the box base snugly.
the bottom of the box has a second layer which holds all the counters in their boxes in place and then the score card and board pieces go on top.
The box was made to be just slightly larger than the score card. The score card was made to be 4 board pieces tall and 6 board pieces wide so the playing board pieces fit nicely on top all in the clear case.
Step 6: Playing the Game.
Picture of Playing the Game.
Once everything has been made and i had finished the box i decided i would give it a little play to test it out :)
the game played really well and the meeple stood up and stayed in position throughout the game perfectly.  all the roads and cities lined up perfectly and looked great.
IneV5 (author)2017-09-26
do you also have an svg file of the meeples.
MercuryCrest (author)2015-02-03
Are the laser-cutter files available for download, by chance?
no sorry as its sorta copyright infringement for me to share the plans etc. so im not going to share them.
wemja (author)backwards lamb2016-01-15
No its not, board games are not protected by copyright law.
Something that is often done is that the rulebook is registered as a literature and the artwork as a work of art. since you redid the artwork and only kept the concept of the game you are fine to upload it.
more details can be found here : https://boardgamegeek.com/thread/493294
You are not making money yourself / causing losses for the author since the plans are free and lasering it is more expensive then buying the print.
There is no malicious intent, you just did this for fun and uploaded it for the big Carcassonne fans (that already bought the game)
ossum (author)wemja2016-08-18
Is that the wrong link? It doesn't seem to answer the question. Or are you just saying that it must be OK because of those examples in the thread?
I know tone can get lost in text, I am really interested in the answer to this, not trying to shoot you down.
wemja (author)ossum2016-10-29
hm sorry for this very late answer, yes it seems like I posted the wrong link.
I wanted to post this link https://boardgamegeek.com/thread/493249/
It looks like i typed the last 2 numbers wrong.
I myself am working on some laser cut carcassonne tiles, i based mine of a version uploaded on thingiverse and made most expansions already.
The only things i still need to do is to design are the meeples, tower segments and gold pieces.
And I need to find a place to laser them.
ossum (author)wemja2016-10-29
Thanks for the response. I actually came across that thread in my searches, it has a lot of good info in it.
CementTruck (author)2015-06-26
This makes my OCD happy. Me likes the symmetry of it all and the fact that the meeples are stored in a block instead of loose.
dbarnold1 (author)2015-03-26
I believe game makers can only copyright the rules, not the board design itself. Hence the 100s of DIY game boards available on this site and sold elsewhere. So no worries, you aren't breaking the law.
mikeasaurus (author)2014-03-20
Carcassonne is one of my favourite boardgames!
doctorkb (author)2014-03-17
It seems to me that there might be a copyright violation in here somewhere...
backwards lamb (author)doctorkb2014-03-17
Maybe, but I'm not selling it I've not published anything that isn't available online elsewhere. This was made purely for my personal use.
Penolopy Bulnick (author)2014-03-13
That looks great! I love the little people!
thanks.
desertsniper (author)2014-03-13
I really wish I had a laser cutter! Great game, awesome 'ible.
i would love to have a personal laser cutter, this one is one i have access to on occasion.
About This Instructable
6,972views
45favorites
License:
Bio: Im a model maker who makes film and game props in my spare time. If you like my work please visit my blog it has ... More »
More by backwards lamb:The Grail Diary From Indiana Jones and the Last CrusadeHow I made A Rogue One Stormtrooper Doll.First Order Stormtrooper Cuff Links.
Add instructable to:
