Wooden Chess Rook piece for the Coffee Table by sridhar_rajagopal
Featured
In this instructable (my very first!), I build a 7in x 3 in (diameter) size Chess Rook piece on a wood lathe. I made this at TechShop!
I recently attended a wood lathe class at the TechShop, and was quite excited to see what I could produce. I wanted to make a nice big chess piece, and chose the rook because it is relatively easy, but also nice enough to stand out on its own (as I was not quite ready to make an entire giant chess board!)
In my first attempt, I made some mistakes - I started off with spindle turning, and then had to move to faceplate turning to hollow out the top of the rook, but it hard to center the (already turned) piece on the faceplate and have it spin without wobbling. A little more research, and with improved techniques, my second attempt was a success! With this instructable, I hope you can avoid the mistakes I made, and take it a step further!
Items required:
3.5 inch square by 12inch block of wood (I used Basswood - available at Woodcraft)
Wood Lathe and associated tools - Roughing Gouge, Skew chisel, detail gouge, parting tool
Screws - 4 #12 screws (to attach piece to faceplate)
Carpenter's pencil (or just regular pencil) to mark measurements
T-square or ruler for measurement
Rotary tool, wood carving tools, hacksaw (optional) to cut out the notches
Ok, let's get started!
Step 1: Prep piece for turning
Since the top part of the piece has to be hollowed out, (I learned this the hard way), prepare for that step by attaching the piece to a faceplate, as you're going to be doing face turning in addition to spindle turning.
First step is to prep the wood block for the lathe. The wood block is 12 inches tall. The piece I'm building is about 7 inches tall (to be proportionate to the diameter of the final piece of about 3 inches), plus another 2 inches as the sacrificial piece to attach to the faceplate. That leaves a 3 inch piece extra, which can be cut off using a band saw.
The 7 inch piece is itself divided into 3 sections, the bottom and top sections 2 inches each, while the center section is 3 inches.
montana mindsmith says: Mar 27, 2013. 8:00 AM
nice work. looks sharp.
duncangallimore says: Mar 15, 2013. 1:21 AM
Great i'ble, Sridhar! I've been looking for a simple-to-follow turning project so will definitely try this. Are you planning to do more pieces to eventually form a set?
The Aviator says: Mar 6, 2013. 9:56 AM
Wow! I love chess and I want to learn to use a lathe. This is a great project :-)
sridhar_rajagopal (author) says: Mar 6, 2013. 1:23 PM
Thanks! :) Now my wife wants me to make 31 more pieces, not to mention a big board for a really large chess set!
pudtiny says: Mar 6, 2013. 7:31 AM
looks good, I would suggest the use of a wedge to even up the piece when you bandsaw the bottom off just to make it a bit safer
sridhar_rajagopal (author) says: Mar 6, 2013. 9:44 AM
Great suggestion!
I held both sides down, so it was safe, but because it angled ever so slightly, the cut was a bit tapered, but easy to smooth off with a belt sander. I'll keep it mind for my next project!
Thanks,
Sridhar
saosport says: Mar 5, 2013. 5:33 AM
cool thanks
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
