Remove these ads by
Signing UpStep 1Required parts and tools
- 1 piece of MDF (whatever size you want your tree - ours was about 70cm x 50cm)
- Red, green and brown paint
- Hot glue sticks (lots of them)
- Slow flash colour-changing RGB 5mm LEDs
- - we used 31 for our size of tree
- - we got ours from ebay.co.uk trader "amigoofchina"
- One or two white LEDs
- - ours also obtained from ebay:amigoofchina
- One resistor for each LED, suitable for your chosen supply voltage (our LEDs came with free resistors for use with 12v)
- One 12v _regulated_ mains adapter
- - also from Ebay
- - rated at 1000 milliamps (the tree uses about 600ma, so we're not running it at maximum)
- - we chose a switched-mode adapter, because they don't get so hot, the voltage regulation is good, and it's protected against overload and short-circuit
- One inline power connector (suitable to attach to whatever connector is on your power adapter)
- One inline fuse holder (for 20mm fuse)
- One 20mm fuse (we used a 1 amp fuse, but it depends how many LEDs you're using - they consume ~20 milliamps each)
- Some flexible insulated wire
- Some solid copper wire
- - we stripped some 3-core mains wire to obtain ours
- Maybe some insulation tubing, or insulating tape
- Some thin card and masking tape
Tools required:
- Jig-saw
- Drill
- 5mm wood drill bit
- sandpaper
- pencil
- paintbrush
- soldering iron and solder
- a couple of screwdrivers
- hot glue gun
I don't know exactly, but roughly:
- for the bit of MDF - £1-2? You generally can't buy such a small piece of MDF on its own, but if you go to a timber merchants with a cutting service they may have an off-cut they'll sell you.
- for the colour-changing LEDs, I used 30 for the tree shown, but you can buy 50 for £8 including postage - http://cgi.ebay.co.uk/50x-RGB-5mm-White-LENs-Diffused-Slow-Colour-Change-LED_W0QQitemZ370068178291QQcmdZViewItemQQptZUK_BOI_Electrical_Components_Supplies_ET?hash=item370068178291&_trksid=p3286.c0.m14&_trkparms=72%3A1301|66%3A2|65%3A12|39%3A1|240%3A1318 (these aren't exactly the type I bought, but I've got some samples of these new diffused ones and they'd be better for the task). I have another, smaller tree with only 10 LEDs, which looks just as good.
- resistors for using the LEDs at 12v - free with the LEDs
- red, green and brown paint - ? No idea. I used some of my kids' paint that was left in the cupboard. Find some kids and look in the back of their cupboard, there's bound to be some left over.
- 12v PSU - I bought mine new from Ebay and I think they cost around £6.
- 2.1mm socket to match the plug on the PSU - £1.59 (http://www.maplin.co.uk/Module.aspx?ModuleNo=1407)
- 20mm fuse holder - 39p (http://www.maplin.co.uk/Module.aspx?ModuleNo=430)
- 20mm fuse - £1.79 (for 10!) (http://www.maplin.co.uk/Module.aspx?ModuleNo=451)
- solid core wire - already had some spare in the garage
- hot glue - 99p for a pack of cheap sticks from the local garden centre - you might not need this for the front if using the diffused LEDs, but still useful to glue everything into place at the back.
I think that's everything.
It's the sort of project where you can reuse stuff you've already got, varying the design to make use of what you find.
If you make one, please send me a picture!
