Step 7Throwing Arm Assembly
The main axels are made from 3/16" steel rod. You could use aluminum if you'd like. It'll be easier to cut but usually costs more. I suppose you could even use a wooden dowel but you'll get a bit more friction. Check the distance between your uprights and cut an appropriate length of rod to serve as your primary axel. Tap it through the hole in your throwing arm. Cut another short piece to go between the lower arms to support your counterweight.
Then it's time to add the release pin. This is the business end of the trebuchet and it's important to mount the pin securely. I used a little length of wire from a jumbo paper clip as my pin. The 1/16" hole I originally drilled to accomodate my pin proved too large. Forcing a bit from a smaller paper clip into the hole along with it made for a nice tight fit. You may even get away with chucking a bit of wire right into your drill and trying to drive it directly into the end of the arm.
comment
Add Comment
Add Comment
