Step 13The hitch in detail
iImage Information
The drawbar needs a hitch to attach to the tractor's drawbar hitch. I attached a flat piece of steel to the underside of the aluminum rod. Notice the right end in the photo. I ground it down to make a round pin and then bent the pin upward so it can fit into a recessed hole in the round rod. The red lines indicate the portion hidden inside the hole. A screw attaches the flat piece to the round rod, but I damaged the threads with a cold chisel so the nut cannot turn or loosen. See the azure blue arrow.
