3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wooden Farm Toys for Haymaking
Step 2Rear of the tractor
Rear of the tractor
 In addition to the piece for the tractor frame, the other key piece (in addition to the wheels) is the axle member.  I cut a notch in the underside of the tractor frame and in the upper side of the axle member to make a tight fitting lap joint.  The red lines define the notch cut into the axle member.  I drilled a 3/16 inch hole across the axle member that also goes through part of the tractor frame.  When the 3/16 inch axle rod is inserted (yellow line), the tractor's main pieces are locked together.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
476
Author:Phil B
I miss the days when magazines like Popular Mechanics had all sorts of DIY projects for making and repairing just about everything. I am enjoying posting things I have learned and done since I got my...
more »
