Wooden Gear Clock
 by marvay
Featured
I've added video of the clock. I will be working on carving out windows in the face of the clock. I will upload pictures and/or a video of that when I am done.
I've been into woodworking for a few years now. I love the idea of being able to make things that I can use. A few years ago I came across a clock that was made out of wood. The face, arms, frame, and gears were all wood. It really impressed me, and I kept it in mind for a future project.
I've decided to take on the wooden clock in this Instructable, and hopefully share what I have learned to help others with similar interests.
One of my goals with this was to use common tools that are more widely available to most people. I didn't use any expensive hard to find wood working machines, or costly software packages when designing this. The software used is either open source, or free, and the machines used are some of the common ones that most woodworkers would have.
Step 1: What You Will Need
Here is a list of things you will need
For Designing:
OpenOffice Calc - For calculating the Gear ratios
free2Design - For designing the gears
Gimp- Modifying and editing images
Blender - For rough modeling gears to make sure there aren't any interferences between gears and axles.
*note - You probably can use Blender to do all the designing, but my Blender skills aren't up to speed. It was easier to draw them dimensionally accurate in a 2D package and import that into blender.
For Woodworking:
Scroll Saw
Drill Press
Miter Saw (Table or Band saw will also work)
Hand Saw
Clamps
Spray Adhesive (3M Super77)
1-40 of 140Next »
blipside says: Apr 9, 2013. 1:07 PM
I just found this instructable. Thanks for sharing. I'll have to spend more time looking at this. I've always wanted to make my own clock, especially since it was something that my great grandfather did. I liked that you use open source software aslo. Thanks again for sharing.
lmvlobos says: Nov 4, 2011. 5:47 PM
rennysoncemann,
Please reread the teachings of Galileo Galilei. It's Physics 101.
Since Galileo discovered the isochronic property of the pendulum, they have been the world's most accurate timekeeping technology until the 1930s. This could NOT be so if the angle of the swing would vary the frequency.
Wider swings do NOT take longer, unless you are comparing a swing of 1 degree v. 179 degrees. Then, the variation in period or frequency is really influenced more by friction in the bearing and air friction.
Clocks, use relatively low angle pendulum swings, so these factors are kept at a minimum as there is less movement. The only reason a clock's pendulum may have a higher mass, is to take advantage of Newton's First Law of Motion to overcome as much of the friction to keep it moving as long as posible. The addition, or subtraction of mass will NOT change the frequency of the pendulum.
The period of swing of a simple gravity pendulum depends on its length, the local strength of gravity, and to a small extent on the maximum angle that the pendulum swings away from vertical, called the amplitude.
It is independent of the mass of the bob.
If the amplitude is limited to small swings, the period T of a simple pendulum, the time taken for a complete cycle, is a function of the length of the pendulum and gravity.
For small swings, the period of swing is approximately the same for different size swings: that is, the period is independent of amplitude.
This property, called isochronism, is the reason pendulums are so useful for timekeeping.
Successive swings of the pendulum, even if changing in amplitude, take the same amount of time.
Thetis in reply to lmvlobosSep 27, 2012. 8:04 AM
Um - strictly speaking, the amplitude of the arc does change the period, because a basic pendulum is not truly isochronous, only very nearly. This is basic horological theory and well known amongst horologists and is due to the differing effect of gravity on the pendulum at different points of the swing. A truly isochronous pendulum would swing not in a perfect circle, but in a slightly modified curve called a cycloid (check out "the tautochrone curve" on Wikipedia). This discrepancy was perceived as a problem in early clocks where the pendulum had to have an enormous swing to unlock the escapement. As rennysoncemann says, Huygens invented "cycloidal cheeks" to try and combat this by modifying the way the pendulum swung. The trouble was that in practice, nobody could make them work.
The advent of the anchor (recoil) escapement effectively solved the problem by massively reducing the required arc of the pendulum thereby making the discrepancy so small, it could be ignored, certainly in domestic clocks. There is still an error however, and to reduce this as much as possible the best quality clocks used by astronomers were designed to have the smallest arc of movement they could get away with. You, in your response also quote that the amplitude of the pendulum must not be large, so I'm not certain why you thought rennysonceman was incorrect?
Similarly, in theory the mass of the pendulum bob is unimportant, but in practice, it is desirable to make it as heavy as possible, but with the smallest surface area possible in order to minimise the effects of air pressure and friction. The smallest surface area would be provided by a sphere; horologists compromise and use a cylinder because it is easier to make. The disc shaped bob invariably found on domestic clocks might seem desirable to reduce air resistance but apparently confers no great advantage.
Sorry, I've drivelled on too much.
rennysoncemann in reply to lmvlobosApr 9, 2012. 10:45 PM
Sorry, but a wider swing takes longer, and it's not because of friction. Christiaan Huygens, who invented the first pendulum clock, realized this fact. His primitive escapement necessitated a very wide swing, so he added so-called "cheeks" to his pendulum suspension, to alter the path the bob takes from a circle to a "cycloid", which is the curve needed to have true isochronism. Read more here:
http://en.wikipedia.org/wiki/Christiaan_Huygens
For small swings, the effect is quite small and could be ignored in a weight driven clock, whose pendulum swings are reasonably constant and therefore unvarying. For spring driven clocks, where the swing gets smaller and smaller as the spring unwinds, the effect was bad enough that a fusee was added to the finest movements to keep the driving force, and therefore pendulum swing, as constant as possible. Cheaper spring driven clocks weren't very accurate anyway, and the recoil escapement used in those movements tended to drive the pendulum faster when wound tight, which partially compensated for the wider (slower) swings of the pendulum. Not that it really mattered in that era, as people set their clocks daily anyway, to a sundial or the town clock bell.....
Cheers,
Chris
jakobus9 says: Apr 29, 2012. 1:53 PM
""One of my goals with this was to use common tools that are more widely available to most people. I didn't use any expensive hard to find wood working machines, or costly software packages when designing this.""
there should be more people with this opinion here!
this is very nice! well done.
BrysonHicks says: Mar 6, 2012. 5:18 PM
Are there any cad files for this? I have access to a laser cutter at my school it uses cad. When ever I try to open any files on this instuctables it gives me .tmp files.
marvay (author) says: Dec 28, 2011. 10:51 AM
I apologize to everyone that have asked for DXF files, or another format from the free2Design program or more information about my Instructable. I have been in and out of Instructables for the past year or so, and haven't kept up with my messages.
The free2Desing program didn't have an export function. I also didn't realize it wouldn't be around for much longer after I used the program. They shortly canceled the project. The reason I used it was that I was looking for a free, easy to use program, that had certain functions that made designing the gears easy.
My main purpose of this Instructable wasn't to make something that everyone could duplicate(you could, but honestly it's an ugly design). It was to teach anyone interested in building a clock, how to figure out their own design. Yes you can buy plans, kits, and other clocks to make, but putting it together doesn't teach why you need certain ratios. It just teaches you how to assemble something.
I hope to make another clock sometime, and if I do, I will make sure it's in a program that most everyone can use.
Thanks for viewing this Instructable and all the comments.
aggrav8d says: Dec 21, 2011. 1:08 PM
Please: could you add your designs as DXF files so that everyone can open them in pretty much any program? My father and I are trying to make this clock for xmas and we can't work with E2 files. Thank you!
uthmod says: Sep 10, 2011. 9:23 PM
the link to the file is broken. It links to a .tmp file instead.
Nice instructable.
lmvlobos says: Sep 3, 2011. 7:25 PM
rennysoncemann, You are incorrect about the properties of a pendulum. The "width of arc of the pendulum swing" does not affect the period...
"The frequency of the pendulum is dependent on the length of the string or wire. The shorter the wire, the greater the frequency or how fast it goes back and forth.
The frequency is independent of the amplitude of the swing, provided the initial angle is not large. At larger angles, there is a slight change in the frequency.
Also, the frequency is independent of the mass of the bob. In other words a pendulum with a heavy bob will move at the same rate as one with a lighter weight bob. But this only makes sense, since the acceleration of gravity on a falling object is independent of the mass of the object."
See:
http://www.school-for-champions.com/science/pendulum.htm
keltnesd says: Jul 13, 2011. 10:10 AM
Really cool ratchet system for your weight axel, I may do something similar. Why do you have the second lever though? I can't seem to work out what it does.
qwerty2008 in reply to keltnesdSep 1, 2011. 1:00 PM
On the ratchet the second lever appears to be a type of spring to keep the other lever engaged into the ratchet system.
dpasqual says: Aug 25, 2011. 11:16 AM
Hello ! OK I know that I'm a newbee. And I know that I speak French and I'm not fluent in English but !!!
I just become a member. And it's very cheap but :
I cannot open any of your files.
Your ods file is not recognised by my Open Office Calc and free2design is not found by my explorer.
Then could you please say me what I'm doing wrong ?
Thank you for your quick answer.
Best to all.
tilmen says: Jun 28, 2011. 10:47 PM
nice work.I'm trying to make small gears.I think I can put some designs nto my website http://tilmen.s5.com/anasayfa.html soon.
ecameron says: Apr 1, 2011. 6:47 AM
Here's one tip on cutting gears with a scroll saw. Since clocks only run in one direction, there's no need to cut the 'back side' tooth profile. That speeds up the process.
Ed
UpgradeTech says: Feb 26, 2009. 1:16 AM
Unfortunately, the freeware version of free2design is unavailable. Are there any other substitutes?
durgledoggy in reply to UpgradeTechJan 29, 2011. 1:16 PM
Be a student and get a student licence for AutoCAD.
Or join their beta program and get their beta software.
Ed2 in reply to UpgradeTechNov 2, 2010. 3:47 AM
The best free computer drafting program out there is at www.allycad.com!
JThomasAlbert in reply to UpgradeTechMay 1, 2009. 6:53 PM
A9CAD is fairly easy to use and totally free.
http://www.a9tech.com/a9cad/
Unfortunately, it does lack certain advanced features that would make your design work a lot faster.
For example, in the case of designing these gears, it would be handy to have a "Polar Array" feature. That's where you select an object or group of objects, Pick a center point, tell the program how many duplicates you want and how many degrees you want it to cover. The program would then automatically rotate and place the objects for you. So, you could draw one tooth of the gear, tell the program how many teeth you need and where the center of the circle is and it would draw the whole gear for you.
Alas, with A9CAD, you would have to draw each tooth individually. :(
Still, it is free and it is effective. I was trained on AutoCAD at work, but couldn't afford a license for home. A9CAD is a good free substitute.
Ed2 in reply to JThomasAlbertNov 2, 2010. 3:55 AM
the free version of allycad will allow you to copy a gear tooth x number of times in a polar fashion around the center! Or if you don't mind metric and using module instead of diametric pitch then use the included tool for drawing involute gears. It's a great program, I've used it for going on 7 years now, and built over 13 clocks using it. One tip. Wood clocks need more clearance and backlash than metal. Part of the fix is to set the centers 0.04" further apart, which with involute gears will not affect their speed.
hondaman900 in reply to JThomasAlbertDec 30, 2009. 3:38 PM
Can it open the "e2" files in the instructable?
kd4uwk says: Jan 13, 2011. 2:43 PM
Thanks This was a big help
In Step 4, there is a spreadsheet with each gear,
the number of teeth, and the ratio that the gear train creates.
But for a quick reference,
here are the Gears and their teeth:
Each line represents an axle
Pinion 1 - 12 teeth Wheel 1 - 36 teeth ,
Pinion 2 - 10 teeth Wheel 2 - 40 teeth,
Pinion 3 - 8 teeth Wheel 3 - 40 teeth,
Pinion 4 - 12 teeth Wheel 4 - 40 teeth,
Pinion 5 10 teeth Wheel 5 - 36 teeth.
The escapement gear has 30 teeth and is not in the list above since it does not factor into the calculation of the gear ratios.
kd4uwk says: Jan 13, 2011. 2:40 PM
Thanks for the work here
I like this & trying to make one
wish i could open the files
or that jpg files cound be downloaded
Ed2 says: Nov 2, 2010. 5:06 AM
Go to abbeyclocks.com or maybe its abbyclock.com. It's a great page by a guy named Mark Headrick. Escapement animations will help ya alot. Plus he has a downloadable (FREE) paper on designing escapements!! It is super!!
DerrickAD in reply to Ed2Dec 17, 2010. 10:22 AM
I've tried to send you a Private Message but it doesn't seem to work. Can you send me one so i can respond?
reichert99 says: Dec 13, 2010. 3:14 PM
am I missing something. When I try to download I get a tmp file. do I need to be a pro member to download?
Ed2 says: Nov 2, 2010. 5:00 AM
Email me for a pdf I made showing a way easier method than Nick's. No offense intended to nick1
Ed2 says: Nov 2, 2010. 4:04 AM
Ya know. The hardest part I ran into 6 years back when I started designing wooden clocks was how to draw a gear tooth. I came up with a easy way to do it and also designed a spread-sheet in open-office to calculate all the necessary info to do it. After clock #2 I gave up on cycloid gears and went to involute gears. I also found that lantern pinions work far and away better than cut pinions plus are easier to make! After building 13 clocks (everytime I put one on the wall someone wanted to buy the thing) and no problems thus far I think I have most of it down pretty good. It is way too addictive!LOL
jackdi says: Sep 30, 2010. 9:18 AM
Wow!
I am extremely amazed!
I hope i would have time to try this out.
Thanks Marvay. Great work!
- Jack -
afenerty says: Sep 11, 2010. 4:30 AM
Im releasing very shortly new software which can help in things such as clocks or geared mechanisms. You can see the tutorials and such now at www.gearotic.com , its inexpensive and should aid in making all things geared much more easy to make and envision.
Thx
Art
stefke says: Jan 15, 2008. 8:53 PM
Cool! Now I know how to build someting like this
Johnsons on fire in reply to stefkeJan 17, 2008. 1:22 PM
I like this one better. (Sry marvey). Can you do an instructable for it?
odisej in reply to Johnsons on fireMay 5, 2010. 12:30 PM
stefke in reply to Johnsons on fireJan 17, 2008. 3:20 PM
This clock is "Simplicity" and you can bay pans for this clock here. But I want to build my own clock and here is two more pictures of that clock.
nandog in reply to stefkeApr 9, 2009. 4:40 PM
wonderfullll it would be great to have this instruct. ps: nice instruc buddy! will work it on some friends cnc
Johnsons on fire in reply to stefkeJan 17, 2008. 6:56 PM
sweet......
marvay (author) in reply to stefkeJan 17, 2008. 6:13 PM
No Problem, I've seen that clock and it is cool. I wasn't going for style on this Instructable. Those are cool, and I've seen several others that are amazing. But the instructable wouldn't be worth much if I said: Step one: Buy Plans Step two: Paste plans on wood and cut. Step Three: Assemble cut parts. I decided to go more into how and why the clock keeps time, and some background on how to design your own. I know this is no work of art, but it's a step in that direction. This is the first clock I've built and designed, and it won't be the last. Thanks for the pics, stefke, if anyone else has pictures of clocks you've built or have seen, please post them. I always like to get ideas for the next clock.
stefke in reply to marvayJan 18, 2008. 2:41 PM
You are right about that instructable will be stupid Step one: Buy Plans Step two: Paste plans on wood and cut. Step Three: Assemble cut parts. This is grate instructable I learn some rely good things about gear clocks and I am planing to build one when some day search on Google "Wooden gear clock" or something like that you will find great clocks, pictures and videos
octochan says: Apr 11, 2009. 8:52 PM
This is a really helpful and interesting instructable on how clocks work! now I merely need to figure out how to apply all this information so I can make a 13 hour clock (that runs 26 hours in a normal 24 hour period).
GreyGhost2 in reply to octochanMay 1, 2010. 5:50 PM
 Ummmmm... Why do you want a 13 hour clock?
1-40 of 140Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
