Most classic toys started out being made of wood. Legos were after all made by a carpenter.
Making system sized bricks is quite a challenge because they have thin spots. Duplo or quarto or would be a bit easier.
It will take a little skill and patience but making your own legos is worth it.
This method requires no special tools(but if I had a mill I would mill them out)
Step 1: Plot It Out
A fine amount of accuracy is needed to insure the bricks clip to one another and their plastic counterparts.
I measured the bricks with a caliper and got some good measurements. I provided them in millimeters, inches and fractional inches (to the nearest 116 so it may not clip to plastic blocks)
The right view is shown only for completeness (it is not needed for dimensioning)
kelseymh says: Feb 17, 2012. 9:46 PM
I am really impressed that you made all of these by hand! This is an obvious (and "relatively" simple) project for a CNC machine. You could mill the studs and holes out of a single block, rather than inserting dowels. Your method is a much better test of skill, and the results would make for some very interesting builds!
jazzzzzz (author) in reply to kelseymhFeb 21, 2012. 10:40 AM
To be honest, if I had a CNC mill I would probably have made them with it.
(still trying by hand for fun)
caarntedd says: Feb 20, 2012. 8:17 PM
This is cool. You could make all sorts of attachments that are compatible with your lego, like the type of stuff you get in the specialised kits.
jazzzzzz (author) in reply to caarnteddFeb 21, 2012. 10:37 AM
Yeah, with enough patience I could make a gear or a minifigure.
GASSYPOOTS says: Feb 20, 2012. 10:49 AM
can you make one on how to make metal ones?
Aegian2424 says: Feb 18, 2012. 3:21 PM
this should win some sort of prize
patriots8888 says: Feb 17, 2012. 5:25 PM
thats pretty nice
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
