Introduction: Wooden Magic Wallet
This wallet is laser cut on 1/8 inch craft plywood, and elastic is sewn on to hold in cards or money.
MATERIALS
- one piece 1/8 inch thick craft plywood, at least 8 x 5.5 inches (or two pieces at least 4 x 2.75 inches each)
- one yard elastic, 1cm thick
- sewing thread and needle
TOOLS
- Laser cutter
- Scissors
- Lighter (to seal ends of elastic)
Step 1: Laser Cut Your Plywood
Cut two of the included file onto your plywood (DXF and SVG file options attached).
Step 2: Visualize Where Your Elastics Will Go
There are eight elastics in total.
Four (on the insides of the wallet) are used for the 'magic wallet' function, and four forming a cross on the outside sides are just for holding extra cards.
Step 3: Prevent Your Elastic From Fraying
Run the end of your elastic back and forth over a lighter to melt the end slightly so it doesn't come apart.
Step 4: Sew in Your Elastic
I did some of this with a sewing machine and the end parts by hand. I don't think I saved any time using the machine since it was so fiddly.
For each end of elastic you sew in, pass between 1 and 2cm of it through the designated hole, fold the 1-2cm end over the rest of the elastic, and sew in place.
If you are picky you may want to plan out which sides you want your elastic ends to be showing on, in advance.
I used a backstitch for hand sewing, but I don't think it matters which you use, so long as it's secure.
There's a great hand sewing tutorial here: https://www.instructables.com/id/How-to-Sew./
Step 5: Trim Off All the Extra Threads
And you're done! Have fun playing with your new magic wallet!
