Wooden Precision Mini Router Base for Rotary Tool (with Cardboard Prototype)
Introduction: Wooden Precision Mini Router Base for Rotary Tool (with Cardboard Prototype)
Leftovers Challenge
Runner Up in the
Leftovers Challenge
I have a Dremel like rotary tool and I wanted a mini router base for it. It can be bought from Dremel or Stewmac e.g.
but I decided to make one. Made an initial research and found some good and nice examples:
I decided to make it 3 legged to increased stability and wanted to try it, so I made a prototype out of cardboard.
Let the fun begin!
Step 1: Template, Tools and Materials
I have laminated floor leftovers and it seems to be good base material. It's flat, the surface is strong and tough enogh, easy to work with. Needed some screws and glue.
  • laminated floor or some wood (6 mm thick)
  • wood glue
  • 3 pcs of 6x80mm hex head bolt screw
  • 12 pcs of 18/6mm washers
  • 6 pcs of 6 mm nuts
  • 3 pcs of 6 mm wing screws
  • citron oil
  • flat and round files
  • flat and round needle files
  • needle polishing stick
  • pencil
  • hobby knife (OLFA)
  • jewellers saw with wood blade
  • metal saw
  • screwdriver with 10 mm hex head nut setter bit
  • 10 mm wrench
  • 6 and 7 mm wood twist drill bits
  • 18 mm wood flat drill bit
  • Dremel router bit
  • vise
  • clamps
  • various grit sandpapers for sanding and polishing
  • masking tape (Tesa)
  • paper glue stick (Pritt)
  • strong universal glue
  • rotary tool
  • hand drill
  • angle grinder
You can download the printable template in PDF format and the SketchUp files of the 3D model. In the _scenes version You can see the step by step assembly sequence and see the video animation for reference.
The model was made in SketchUp, You can download it for free directly from the owner and developer of it. (Previously it was Google.)
Here is the download link: SketchUp Make (http://www.sketchup.com/products/sketchup-make)
Added a PDF with dimensions on it.
Step 2: Cardboard Prototype
I found some proper 6 mm thick cardboard. Printed my template and glued to the cardboard. To cut the cardboard used the jewellers saw, then glued together the 2 layers of the base. Finaly assembled it and gave a test run. Surprisingly it's strong and stable enough and works like a charm. The 3rd leg helps to hold it better.
The conception is proved to be good for my needs. It's compact, stable, lightweight, easy to controll. Let's make the real one!
Step 3: Preparation and Test Drills
Printed again the templates, enfolded the surfaces with masking tape and glued the templates on it with paper glue stick. This way there is no need to copy the template to the workpieces, it's accurate as it can be, the masking tape protects the surfaces and the edges and easily can be peel off.
After that I made some test drills. Everything was fine, but this stage I decided not to fully drill thru the boreholes of th washers. I wanted to keep 1 mm bottom, this way it gives stronger structure to hold the 2 layers of the base. But the flat bit made a rounded bottom. Guess the solution! Yes, I used the cardboard prototype to flatten it. Ready to drill the workpieces.
Step 4: Make It Real
So the pieces are prepared, drill the holes. 18 mm for the rotery tool and for the washers, 6 mm for the screws on the base and 7 mm on the top plate. With needle files widen the top plate 7 mm holes to insert some alu pipe pieces to protect the wood. Remember, this piece is the moving part with the screw threads in it.
Glue together the 2 layers of the base, use the screws to align it and tighten the screws and add som more clamp to hold it tight. When the glue cured shape the sides with the rotary tool, files and sandpapers. At this phase I made a simple dust collector out of a PET bottle attached to the vacuum cleaner. When the shaping done polish the sides and apply some citron oil.
Before the assembly needed to flatten and thin the hex head bolts. The laminated floor is 6 mm thick, there is 1 mm excess on the bottom, the washer is 1.3 mm and the bolt is 4.7 mm so I grinded down 2.5 mm with the angle grinder.
Ready to final assembly.
Step 5: Put It Together
The final assembly sequence is:
  • screw
  • washer
  • base
  • washer
  • nut
  • nut
  • washer
  • top plate
  • washer
  • wing screw
  • rotary tool
Tighten the screw and nuts on the base, adjust the top nuts and wing screws as needed. You can fine level it and it gives stable, strong structure. Now You have a compact, lightweight, strong and stable cheap and easy to make mini router base. :)
On the video You can see how it's attached to the rotary tool.
Step 6: Dust Extraction
You can add some dust extraction to the base. Drill two 10 mm hole to the end of a flaxi tube attached to vacuum cleaner. Attach the tube between the base and the top plate with the screw. It will hold it in place and the tube extracts the dust as near as possible from the router bit. Works very well.
Step 7: Test Run
Recently I started to make myself a 2in1 bench pin with vise. It can be secured to the table with clamps. Another method is a 2in1 solution, clamp the bench pin with a vise. So I made a cutout for that and needed to lower a seat for the vise. Here comes the mini router setup. And finaly done, the mini router base works as I expected.
On the video above You can see the next mission with the router base where I made a hanger (ible coming soon about it) for my Foredom flex shaft motor I won here on Instructables by a pair of 3D Layered Veneer Earrings „Venearrings".
If You have a Dremel like rotary tool You will love it, extends the possibilities. All You need is some leftover wood or laminated floor and some screws, nuts and bolts.
Entered it to the Leftovers contest, if You like it and think it's a good use of excess materials, please vote it. Happy making!
  • Paper Contest 2018
    Paper Contest 2018
  • Science of Cooking
    Science of Cooking
  • Pro Tips Challenge
    Pro Tips Challenge
Thank you. The video is helpful. Even a few seconds of it gave me a better grasp of how the bolts worked to adjust the depth of the router bit. I suspect that my dremel tool is pretty old; at least I don't recall it having any threaded nose piece. And that video features that screw on part well. I thought that my old one just had a slide-on shaft with parallel channels or cogs running parallel to the center axis of the shaft rotation. A true Dremel router base would slide on, in line with matching cogs, or grooves, and then was fixed in place by a set screw. Ha! I'm still just looking for where I stored mine, so I can't be sure I'm remembering it accurately. When I find it, I think your design with suggest a workable option, so thanks a lot.
You're welcome, I'm glad. :) I'm sure You will figure out the best methode to attach Your tool. Please, show it us when finished. :) Have fun!
As I am browsing thru a nice but long list of plunge-bases for my hand held Dremel (it didn't come with the base... 2nd hand thrift), I was trying to find a good design for attaching the base to the dremel tool. I like the looks of this base, but like lots of posts here on Instructables, the text is pretty linear: not broken down as in a charted diagram. I don't see how the base is to be secured to the tool (or vise versa :-). Were is that part of the instructions, or can you briefly say how that attachment is done?
Thank You for Your feedback Cantoo.
Of course, I made a short video about it, this and some pictures will help I hope. :)
Youtube video link.
Great share, thanks. I have to find a way to adapt it for a foredom handoiece now.
Thank You TattooGabby!
I'm also planning something similiar for my Foredom basic handpiece for more detailed works. I think I'll modify only the attaching method at first.
Then there are different approaches, here is two nice other examples, You can choose which one fits better for Your needs and ideas, and also great inspirations.
Please come back and show us Your version! Have fun! :)
I can't see exactly how the Dremel is secured to the base you have made. Could you please advise us?
Yes, I use the plastic fastener part that came with the machine (just Dremel like, not Dremel).
I don't see how your threads come thru this far with a 1/4 " thick material only one thread is exposed on my tool??
The threads are long enough in this machine. Here are some better pics.
