Wooden Micro USB Charger Plug
3,522
69
5
Posted
Introduction: Wooden Micro USB Charger Plug
The plastic encasing of my Android charger plug broke. usually after long use,the area that connects to the male plug gets loose and cause charging issues before completely broke, so what we do is usually buying a new charger and throw the old one..because for most people, it's irreparable, unless you are able to replace the cable with new one
Well i didn't want throw it, i wanted fix it so i opened the plastic casing only to totally tear it apart. so i took the plug out and designed a wooden encasing for it.
It looks cool after built, i have never seen anything like it before lolz i could make it in first attempt even though it took around 3 hours to build..but it worths cause it can be used for long time now
Step 1: Tools Needed
• Small Handsaw
• Thin knife
• Soldering Iron
• Wood Glue
• Sand Paper
• Any other tool that's useful
Step 2: The Making
• Cut wood for appropriate size
• Create a rail in the middle of the woods in the width of the plug, it should be tight, not moving here and there like old men's teeth
• Attach the plug, glue a small piece of Wood behind the plug for support, so the plug won't move backward when force into charging socket
• Make the tail tube with wood, i used the yellow wood so it would look cool
• Tie the cord a lil before the tail so the cord won't fall out when pulled, and solder the red and black wires on the plug, must be careful, use a USB pinout to find out the pin order of red and black, (+ and -)
• Glue it
• Sand and make it shape, that's it. if needs more explanation, i will reply on comments
Step 3: End Result
It's amazing to see how a piece of wood turns to such useful things. i love wood!
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
    4 Comments
    because it is PLASTIC......
    lol yes,,i am converting everything that is possible for wooden encasing to wood. woodTronics if it's right to call a wood and electronic combination
    thank you for correction
