Introduction: Wooden Pallet Coffeetable
Picture of Wooden Pallet Coffeetable
This table is a cool way to reuse some wooden pallets.
Step 1: Obtain Pallets
Picture of Obtain Pallets
Find 4-6 wooden pallets that have been weathered slightly. make sure that most of the wooden boards are not broken so they can be used later.
Step 2: Salvage the Pallets
Picture of Salvage the Pallets
take apart the pallets to salvage the boards. keep the good ones and toss the bad ones (thats why you want more rather than less).
Step 3: Aline the Wooden 1 by 6's
Picture of Aline the Wooden 1 by 6's
put the 1*6's in a line so that 1 inch sides are touching the next one.
Step 4: Connect the Boards
Picture of Connect the Boards
lay the 2 by 4s perpendicular on the 1 by 6s. this you will need to screw together with screws.
Step 5: Cut Your Table Into a Hexagon.
Picture of Cut Your Table Into a Hexagon.
find the midpoints on 2 opposite ends of the table. Then from those point go at a 60 degree angle either way. this will create a 60 degree interior angle on 6 corners.
Step 6: Cut Out the Perimeter
Picture of Cut Out the Perimeter
take 6, 2 by 4s and cut each end at a 60 degree angle so that it can create the perimeter. connectand pocket screw these 6 sides around the table.
Step 7: Sand Down the Table Top
Picture of Sand Down the Table Top
use a orbital, mouse, or belt sander with 60 grit to sand down the top of your table. when smooth increase grit to 120 and continue to sand until smooth.
Step 8: Cut Legs
Picture of Cut Legs
get 3, 2 by 4s that are 36 inches long and cut them in half. this way you will have 6 legs that are 18 inches each.
Step 9: Stain Table
Picture of Stain Table
use preferred stain to stain the legs and table top to darkness that you would like.
Step 10: Attach Legs
Picture of Attach Legs
use 3-4 screws and pocket screw the legs onto the perimeter
Step 11:
now your table is complete
doing2much (author)2016-12-16
Good work, and nice way to recycle! You just got my vote. :)
ClenseYourPallet (author)2016-12-14
Great pallet project!! Thanks for sharing
Swansong (author)2016-12-14
It looks really nice, I like the stain you picked. :)
About This Instructable
4,714views
130favorites
License:
More by daphillips39:Wooden Pallet Coffeetable
Add instructable to:
