Wooden Plate That Turns Into a Table
Introduction: Wooden Plate That Turns Into a Table
Today I am making a transofrmer plate that can turn into a table
Very easy to design and assemble
The design assembly is as shown in the above figures
Step 1: Design on SolidWorks
First design on SolidWorks
SolidWorks file is avalible to download below with dimensions
Export DXF extension files from Solidworks parts using top view
Step 2: Laser Cut
On a laser cutter cut the DXF files extruded from SolidWorks
For image Scaning:
Power 20%, Speed 150 mm/sec
For cutting:
Power 75%, Speed 22 mm/sec
Step 3: Assemble Final Product
After assembling parts as shown in SolidWorks file the final product should look like this
    • Paper Contest 2018
      Paper Contest 2018
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    I can't tell - when it's in "table" mode, what stops the inner circles dropping right through?
    it's interference fit, you can apply any light weight on top. but if you applied a heavy load it will fall down
    Awesome design
    put i have a inquire
    is height is adjustable to 0 and maximum height only
    or any height can be apply
    you can change the design to apply any height you want
    Awesome table design. This is probably the first adjustable table that I have seen that could change its diameter. Very cool.
    Thank you very much =))
