loading
Step 5: Turn the Blank to Shape.
Chuck the rocket blank in your wood lathe. I stabilized mine using a live center in the tailstock, and I got the blank as close to centered on the lathe as I could by locating the center of the bottom of the blank.
Move the tool rest as close to your blank as possible. Test for interference by manually turning your blank on the lathe, and adjust the location of the tool rest if the blank hits it.
Using a roughing gouge, turn the blank at a relatively slow speed. You're going to need to stabilize the gouge on the tool rest, as you turn the square cross-section into a rounded one. The different textures of the different woods in the blank may be difficult to manage; some woods are prone to chunking out while you are turning them, and that was the case with my walnut.
Once your blank is rounded over, use whatever lathe tools you want to turn your blank down to approximate your intended shape. In my case, I used a smaller roughing gouge and a round nose scraper to shape the blank. If you are new to wood lathing, you should take a look at this Make article where they discuss the different types of lathe tools. You can also bump the speed up slightly. This also is the time when you'll start to deal with the acrylic rod. It'll have a different texture when you're turning than the other sections of your blank, but it handles just fine.
If you lathe away so much material that you start to see a noticeable gap between the tool rest and the surface of your work, stop the lathe and adjust your tool rest up to the new edge of your blank.
<p>Nice build! According to my experience, you may get a clear aspect to the acrylic without using super glue, just by sanding to a higher grit.</p><p>I do this for acrylic pen blanks. I use micromesh sanding pads, going up to 12.000 (slightly wet the pads to avoid super fine dust).</p><p>I guarantee your acrylic window would look clear again with grits above 1.000 :)</p>
<p>That's a great tip! Our shop very rarely has sandpaper over 400 grit since we're an academic makerspace and students rarely have the patience for that much sanding, so I don't have a lot of experience with crazy fine grits. Maybe we should invest in some. Thanks!</p>
<p>now give it a flip top &amp; put a shot glass inside; you're welcome. &quot;Rocket shot&quot;<br><br>ADD or give it a flip top &amp; put a 50ml bottle inside</p>
<p>Cool!</p>
<p>Very Cool, Thanks for sharing.</p>
<p>As the recipient of the original, I can confirm that it's a pretty awesome gift! At some point I think I'll make a little light-up stand for it or something.</p>
<p>How about an LED that shines up through the bottom of the acrylic rod and illumiates the windows?</p>
The acrylic is inserted from the side so I'd need to drill up through the bottom in order to do that. Although I'm sure I could make it work I'd rather not modify the rocket itself.
<p>This turned out really well! It's adorable :)</p>
<p>I love lathe puns!</p>
Really nice! Voted
<p>Thank you so much!</p>
<p>That is wonderful, definitely going to have to try this project out. Thanks for sharing!</p>
<p>Thanks! It was a pretty quick project - like 2 days of work - especially if you do the fins more efficiently than I did, haha.</p>
<p>Absolutely beautiful!</p>
About This Instructable
15,899views
238favorites
License:
Bio: I'm an engineer, designer, and maker studying at the Georgia Institute of Technology.
More by vspencer:Make MDF Look Like Ceramic Wooden Rocket with a See-Through Window Paper Circuit Simon Says
Add instructable to:
