Introduction: Wooden Viking Bearded Axe
Since my audience wanted me to make an bearded Viking axe I decided to make one and here it is.
Check out my YT channel:
Step 1: Axe Shape
Draw your design and cut it out with jigsaw
Step 2: Glue Time
Glue to get more thickness around the axe eye socket
Step 3: Clean and Drill
Cut out the excess wood with coping saw
Drill out the eye socket
Step 4: Forging
Remove waste wood to get axe shape you want
Make a bevel on the edge and don't cut yourself on it (like me)
Give it some texture with a hammer
Step 5: Paint (the Most Critical Part)
First seal it with sealer (In my case it's nitro lacquer)
Apply 2 or 3 coats of silver spray
When dry apply the black spray from distance
after all this steps your axe will look like cast iron :/ but to make it aged/epic
use a trick which I accidentally found out:
Apply paint thinner on piece of cloth and rub it on to get aged look
PS just don't overdo it but if you do you can apply more silver and black spray and repeat the process
Step 6: Handle
Plane it to fit the eye socket on your axe head
Cut out the wedge slot
Stain it to match aged look of axe head
Step 7: Fitting
Hammer on the axe on handle and insert the wedge
Step 8: An Epic Looking Axe
Finished axe
Please if you have some questions write me a comment down below or send me a message me via Instagram
I am happy to help anytime... sometimes I even sleep :p
Please be sure to watch the video and give me your opinion :)
Build a Tool Contest 2017
Woodworking Contest 2017
