Introduction: Rainbow Wooden Water Color Skyline Wall Art
Make a beautiful wall art hanging with reclaimed wood, a laser cutter and watercolor!
Step 1: Supplies
-A Piece of Reclaimed wood, rectangular shaped, or you can cut it to be a rectangle
-The piece I used came from the old deck (I believe it was a floorboard)
-A black and white image (from google) of your favorite city's silhouette
-Watercolor paints
-A laser engraver
-Optional: Clear varnish
Step 2: Laser Cutting the Skyline
-Set up the drawing file (I used Inventor) with the image and vector lines around it, leaving extra space on the bottom of the skyline image
-Get your laser engraver ready to go and place the wood piece in the cutter
-Engrave!
Step 3: Watercolor Painting
-Paint in the water color pigment heavily in the top part of the skyline
-Use whatever colors you would like, making sure to cover most of the image
-Have a cup of water and brushes handy
-Use the water to blend the paint down the picture, allowing drips to run down the wood
-You will need a lot of water to make the pigment flow down the board and create the drippy look
-It was helpful to paint in the pigment while the board was laying down, and lean it up on something for putting the water on so that the paint dripped down
-Let dry
Step 4: Optional Varnishing
-After it has dried, use a clear varnish to seal in the paint and keep the wood water tight
-I used DEFT clear wood finish gloss spray
-The finish is a good idea if the art will be hanging outside in the weather, as if the watercolor is exposed to water it will run, but the clear coat will protect it
-If you decide to finish it, make sure you are in a well ventilated area so that the fumes will not hurt you
Step 5: Done! Admire Your Beautiful Work
-Hang it up
-Or lean it against a wall
-Enjoy!
Reclaimed Wood Contest 2016
First Time Author Contest 2016
