Wooden Workshop Shed
Published
Introduction: Wooden Workshop Shed
About: I enjoy building things.
I built this shed three years ago. I use it for welding and painting.
Step 1: Materials
The wood comes from the remains of building a house.
The only new things were nails, 2mm wire, 3mm wire and polyethylene film.
Step 2: Big Frame Construction
The beam length is 7m and columns have 3m high.
Step 3: Lifting Big Frame
You should remember that I lifted her alone and therefore took longer.
Step 4: Small Frame Construction
The beam length is 7m and columns have 2.2m high.
Step 5: Lifting Small Frame
It went a little faster because I was more experienced.
Step 6: Installing the Rafters
Rafters are made of boards 2.5 cm thick and 15 cm wide.
They have 6m length and installed at 1 m distance.
Step 7: 2 Mm Wire
2mm wire placed at 25 cm distance.
Step 8: Mounting Polyethylene Film
I used UV resistant polyethylene. Over it I put 3mm wire to help it withstand the wind.
Step 9: Using It
I used it until spring 2014 when I moved into the back garden to be used as greenhouse.
But that is another story.
Step 10:
    • Outdoor Fitness Challenge
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    2 Comments
    I need to make me a smaller sized one :) My husband doesnt like me painting in the garages. And I dont like the dirt that gets stuck to my stuff when I paint outside. This would be perfect and have multiple uses. Lots of Light and fresh air coming through. Its simple I like it.
