Introduction: Wooden Animal Trap
Picture of Wooden Animal Trap
animal are great!
except when they are wild animals that eat the chickens that are in your backyard
there are coyotes where i live and they have eaten 3 of our chickens
Step 1: Items & Tools Needed
Picture of Items & Tools Needed
items
  1. a pallet
  2. an 8 in by 1 in piece of wood
  3. 2 ft by 5 in piece of wood
  4. four 24 in by 5 in pieces of wood
  5. one 13 in by 5 in piece of wood
  6. three19 in by 4 in piece of wood
  7. two 24 in by 32 in pieces of plywood
  8. 13 in by 26 in piece of plywood
  9. lots and lots of wood screws (i used about 52)
  10. some fishing line
tools
  1. drill
  2. prybar (or anything to take apart skids)
Step 2: Take Apart the Skids
Picture of Take Apart the Skids
for this step you will need a prybar (i don't have one so i used a shovel)
take off the three pieces of wood that are on the bottom
Step 3: Saw the Skids in Half
Picture of Saw the Skids in Half
saw the skid in half (like shown in picture )
NOTE: the two boards on the sides should be taken off
Step 4: Screw Some Boards On
Picture of Screw Some Boards On
screw the two of the 24 in boards onto the top corners (i used four screws on each side of the board)
then flip it over and do the same thing
Step 5: Screw the Plywood On
Picture of Screw the Plywood On
screw the plywood onto the top between the two boards (this isn't structural but it will keep the animal in)
flip it over and do the same on the other side
now you should have a nice little crate!
Step 6: Screw the Pressure Plate On
Picture of Screw the Pressure Plate On
get the hinge and screw it into the 13 in board make sure the barrel of the hinge is facing you
then screw the hinge and board about half way in the crate
Step 7: Make a Door!
Picture of Make a Door!
find the middle of the 2 ft by 5 inboard and mark it (long ways and across) then mark the middle of the 19 in by 4 in boards (across
screw a 19 in board into the middle of it and screw the other 19 in boards about an inch away from the ends (using 3 screws)
Step 8: Screw the Door On
Picture of Screw the Door On
get the hinge and screw it on to the door (make sure the hinge barrel is not facing you) and then on to the middle of the end of the crate
Step 9: Screw a Screw In
Picture of Screw a Screw In
screw a long screw 7 inches down from the door (make sure the screw is on the same side as the screw on the pressure plate
Step 10: Make the Trigger
Picture of Make the Trigger
NOTE: you will have to play around with the length of the string you want it long enough that the pressure plate goes up
crew a small wood screw into the corner of the pressure plate and tie one end of the string to it
then drill a hole in to the 8 in piece of wood and put the string through the hole and tie it
cut a notch in to the 8 in piece of wood 1 inch from the end on the same end as the hole (see picture)
see picture for the way to set it
Step 11: Test It
Picture of Test It
test the trigger mechanism
Step 12: You Are Done!
congratulations!
you have made a wooden animal trap!
now put it in your backyard with the appropriate food for the animal you are trying to catch
gailmac (author)2015-04-21
I protect my chickens vs. trying to trap anything that may eat them (that includes Federally protected raptors). I would caution that your state may require a trapping permit prior to placing the trap, and this time of year many baby animals are born that die because people think it is humane to trap. Once trapped, what do you plan to do with the animal (skunk, raccoon, opossum or maybe the neighbor cat/dog)?
yugnats (author)gailmac2015-04-21
I agree, I hope there is a humane way of letting the animals you trap, out. it seems it would be easier to protect the chickens rather than trapping predators :)
ClenseYourPallet (author)2015-04-20
Simple, effective and awesome. Thanks for the great ible. I would love to see if you catch something
thanks!
seamster (author)2015-04-20
Ha! So cool!
I made an animal trap like this when I was a kid. Sadly, I never caught anything! :( Have you had any luck?
thanks!
i haven't put it out yet
i will post if i catch any thing!
About This Instructable
1,683views
25favorites
License:
Bio: I'm16 and in my free time I control cockroaches, weld, make canoes from duct tape, 3D print, make helmets, light big pieces of wood ... More »
More by bravoechonovember1:Sprinkler Chicken FenceCopper Crystal RingIn-drawer Knife Organizer
Add instructable to:
