I had a brilliant lying in a little box on my desk and I really love rings.
I decided to put that gem on a ring and to give it to my girlfriend.
But I am not a jeweler nor I have the right equipment, so I decided to use wood as raw material and to use my limited set of utensils.
I actually did not use it for a proposal, I just gave it to my girlfriend as a normal gift.
But it can be a good engagement ring for the guys that want to give something special to their lovers.
The close-up pictures were taken with a Pentax K10 D and a Tamron AF 90mm f/2.8 SP Di macro lens.
The other pictures, with a Pentax SMC-DA 16-45mm f/4 ED AL zoom lens.
Remove these ads by
Signing UpStep 1Materials
I found one in a ear-ring that was lying on the floor of a train station (lucky uh?).
I believe that it is a cubic zirconia gem, but I am not an expert, so as far as I know it can be a real diamond!
If you are not so lucky you can easily buy a cubic zirconia, or a real diamond, from eBay.
Sometimes cubic zirconia is referres as "synthetic diamond" or "lab created diamond".
Then you need some wood.
I used a dark-red wood, but do not ask me what kind is it. I think that it comes from an old broken wine barrel, since I found it in an old cellar.
Epoxy glue
To glue the brilliant on the wood. I hope that it will keep the brilliant in place. I also tried Cyanoacrylate glue (here in Italy "super attak") but it did not work, after a couple of days the gem fell off (fortunately I did not loose it).
I ended up having to make a second ring for her because the first one was way to loose. I made a cherry ring first, then I failed a few times at making a black walnut ring. I ended up using a piece of cherry and black walnut together so the cherry would support the black walnut. Wood glue works great to bind them together.
One thing that helps is I own a sawmill business so I have access to all the hardwood I need! The black walnut log came from my neighbor and the cherry came from a family friend.
How did your cherry ring(s) turn out? I'll post pictures of what I made tomorrow and again thank you so much!
I just found some cherry, I am planning to make some more rings with it.
Let us see how they will come :)
I used a pinkish section, inlaid it with an abalone shell heart and polished with 1200 grit wet and dry and then ran over it with a polishing wheel on a dremel. The close grain of yew gets you a really nice finish.
I've become increasingly worried about the toxic properties of yew. According to research I can find the wood itself is toxic, not just the dust (and leaves and berries of course). Close contact with skin doesn't seem to be wise although perhaps the skin's oils on the ring form a protective barrier?
Yes, every part of the yew tree is poisonous apart from the flesh of the berries (the seed is still poisonous though!). Horses have died from eating the leaves. I'm not sure if the poison is a contact poison, or weather seasoning the wood breaks the toxins down. The amount of poison contained within a small piece of wood must also be fairly limited.
It's used extensively in furniture though, and was the wood of choice for bows throughout the ages so I don't think it's like ricin!
you can buy one for about 10 bucks just go slow and it wont crack. the only type of wood that has cracked on me was a bocote the first time and it was because i was drilling with the grain. like somebody already mentioned if you go perpendicular to the grain it will be stronger. i wear different ones about everyday and the only one that broke was one that got stuck on my nephews finger and i tried getting it off dry instead of using soap. lesson learned. i used wax as a polish at first but quickly realized that wax scuffs too easily and have since been coating every piece of jewelry with a lacquer spray. here's a pic of the bocote.
A guy my dad knew was planning to marry a woman who was originally from china. He spent six months arranging to get a piece of wood from the tree that grew in the back yard of her home in her remote village so that he could do this. He got it and made it into a ring all without her knowing. Amazing stuff, love.
