Flickr set of the whole process
You'll need:
a) Some wood stock with a figure that you like. I went with Cocobolo from InternetLumber, their samples are dirt cheap and the perfect size for this project.
b) A donor watch to mercilessly shred to pieces. A bigger face certainly helps to show off your work later, so keep this in mind when shopping. I would also tip any watch you are considering to use at an angle and make sure there is a little room between the hands an the face (the less space now, the more sanding later to make everything fit back together). I settled on a Zane from Fossil.
c) A few common and specialized tools. Outlined within, don't worry, you can fake most of the uncommon tools.
Remove these ads by
Signing UpStep 1: A bit of prep work
Things you'll need to buy/dig out of your junk drawer
- Base watch (see intro for my source)
- Wood stock - 2"x2" (see intro for my source)
- Sandpaper (100, 200, 400, 800 grits)
- Masking tape
- Spray high gloss lacquer
- Fine toothed saw
- Double sided tape
- Cardstock for face template
- Clean work surface with a bright light so you can track down tiny piece when then spring from your hands and clatter to your bench
- .75mm center punch I chocked a hardened nail up in my drillpress - read: ghetto lathe - and filed it to size
- Watch hand setting tool Taking the guts out of a mechanical pencil and sanding the lead guide off the tip will open a hole the perfect size
- Movement pad A soda bottle cap with a hole drilled in it served well enough for me, but something with a little more grip would be ideal
- Watch hand puller - on eBay for a song
Rough Prep
I couldn't find a saw with fine teeth or most of the sandpaper I would need, so I ran out to Home Depot. The sandpaper was no problem, but they didn't have a saw at a price I was willing to pay, then I remembered that they had a station set up for people to cut their own molding. A few minutes and improvised jigs later I had my stock cut to rough size.
Visit Our Store »
Go Pro Today »
TopherWiles
http://www.helpsonline.net
I went to that website internet lumber, but I couldn't find the samples on the site.
help would be greatly appreciated
http://www.woodcraft.com/stores/
Hopefully there is one near you. The one closest to me is about 50 miles away. I venture up there every couple of months for exotic woods and lathe parts.
Enjoy,
Jessifu
I'm gonna try this one, with a twist!
As a follow up on sources, for those who want to skin an existing face without going through all of the trouble of sanding, check out cards of wood, they carry super thin veneers with an adhesive backer that I recently used on my business cards that turned out quite well.
I have to assume that somewhere out there on the web I can track down bits meant for a different watch with a thicker face that I can swap in.
I ended up going with a piece of solid stock for a couple reasons. First, I couldn't find veneer I liked at any of the local woodcrafting shops - it was all birch maple and walnut in huge sheets. Secondly, the face is actually structural, so I would have had to fit the veneer to a rigid substrate and sand that to fit. Believe you me, I was looking for anyway I could to avoid spending that much quality time with a sanding block.
If I can find a way to mill a rigid blank face, I have a few ideas for future watches. French Paper has some killer patterns I'd love to use. I've also been kicking around ideas on how to make a face out of leather airbrushed to look like my skin, so the hands appear to be floating directly on my arm.
To all, thanks for the kind words.
It's positively lurvely. Excellent job. this reminds me that I need to get started on that wooden clock I've been meaning to build.
