3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wooden faced wristwatch
I have a thing for watches, and nicely figured wood, sadly I've only been able to find a couple of wood based watches. It sounded like a lovely weekend project to fab up a new face for a regular watch, so I went for it.
Flickr set of the whole process
You'll need:
a) Some wood stock with a figure that you like. I went with Cocobolo from InternetLumber, their samples are dirt cheap and the perfect size for this project.
b) A donor watch to mercilessly shred to pieces. A bigger face certainly helps to show off your work later, so keep this in mind when shopping. I would also tip any watch you are considering to use at an angle and make sure there is a little room between the hands an the face (the less space now, the more sanding later to make everything fit back together). I settled on a Zane from Fossil.
c) A few common and specialized tools. Outlined within, don't worry, you can fake most of the uncommon tools.
Step 1A bit of prep work
A bit of prep work
  • last photo ←
First a little shopping list:
Things you'll need to buy/dig out of your junk drawer
  • Base watch (see intro for my source)
  • Wood stock - 2"x2" (see intro for my source)
  • Sandpaper (100, 200, 400, 800 grits)
  • Masking tape
  • Spray high gloss lacquer
  • Fine toothed saw
  • Double sided tape
  • Cardstock for face template
  • Clean work surface with a bright light so you can track down tiny piece when then spring from your hands and clatter to your bench
Specialty tools you can fake
  • .75mm center punch I chocked a hardened nail up in my drillpress - read: ghetto lathe - and filed it to size
  • Watch hand setting tool Taking the guts out of a mechanical pencil and sanding the lead guide off the tip will open a hole the perfect size
  • Movement pad A soda bottle cap with a hole drilled in it served well enough for me, but something with a little more grip would be ideal
Specialty tools you are better off buying
Disclaimer - There are easily sourced 'proper' tools for everything listed above, but in the spirit of DIY I picked the roll your own route. Just keep in mind that your cobbled together toolkit has a higher than average chance of causing a little damage to your work in progress. I narrowly missed putting deep gouges into the finish of my more than once of twice when a tool slipped
Rough Prep
I couldn't find a saw with fine teeth or most of the sandpaper I would need, so I ran out to Home Depot. The sandpaper was no problem, but they didn't have a saw at a price I was willing to pay, then I remembered that they had a station set up for people to cut their own molding. A few minutes and improvised jigs later I had my stock cut to rough size.
138 comments
1-40 of 138next »
Jun 7, 2011. 2:02 PMdougturnsy says:
veneer = a 1/4 of the time used.
Jan 16, 2012. 2:13 PMmojo13 says:
First thing the went through my mind!
Dec 31, 2011. 4:53 PMbuilding king says:
That was what I was thinking!
Jul 15, 2011. 1:04 PMmuiftikhar says:
thats great
Apr 2, 2010. 2:30 AMSchokokeks says:
I took an olive wooden teaspoon to make the veneer. Doing this project was fun! Thank you for this instructable!
Apr 2, 2010. 2:57 AMSchokokeks says:
Mar 11, 2011. 10:16 PMdavidjbrock says:
This is very nice. A different look , but very elegant. What wood did you use?
Mar 11, 2011. 11:12 PMSchokokeks says:
Thank you. I used the wood of an olive tree.
Jan 11, 2011. 10:24 PMPreCast says:
Oh men beutiful watch.....
Jan 4, 2011. 10:59 AMludesigned says:
beautiful, great job
Nov 10, 2010. 4:02 PMhottamaleindustries says:
I wonder... Could one combine this instructable with http://www.instructables.com/id/Make-An-Infinity-Mirror/ and make an infinity mirror watch? Obviously, I would need to buy a bigger watch.
Dec 31, 2010. 6:02 PMEvan606 says:
Yeah you could but the hard part would be being able to get the light casing small enough. You would also have to cover the back of the clock mechanism or else it would show in the mirror.
Nov 11, 2010. 4:50 AMcarpe_noctem says:
i used to "work" at this furniture art program thing (it was a city sponsored program, long story) and we had wet sand paper that went up to 20000 grit, no joke. The finest of it feels like soft leather. Using it i was able to get a mirror shine(no exaggeration) on a piece i was working on. This stuff would be perfectly suited to this, as the wood is safe from abrasion behind the glass. Also, i don't think the kit is very expensive, and can also be used to polish out scratches on ipod screens or whatever. I heard the original use of it was for aircraft windshields.
Nov 11, 2010. 4:42 AMwangdong798 says:
That's cool.I'll have a try.
Nov 10, 2010. 9:48 PMsukinmaru says:
My brother has that exact same watch!
Nov 10, 2010. 7:39 PMpchalita says:
Great Instructable!!! can´t wait to do it myself... +1000
Nov 10, 2010. 5:58 PMskelly7447 says:
how much, no seriously. like not as a joke
Mar 5, 2010. 4:38 PMhivoltage says:
 Finally got around to doing this project!  I used Padauk for the face.
Nov 10, 2010. 7:23 AMTopherWiles says:
That's gorgeous! You guys have convinced me that it's time to do a woodgrain!
TopherWiles
http://www.helpsonline.net
Nov 10, 2010. 5:03 AMwobbler says:
Maybe you could apply the double sided tape first to the back of the wood to hold it together more as you sanded? The light wood has an interesting grain. Nice job!
Sep 28, 2010. 12:10 AMimjasonc says:
looks classy
Mar 29, 2010. 9:13 AMtofu4tortoise says:
 instead of sending it down all the way like that, why don't you just buy veneer instead? veneer is cuts of wood 1/64" thick or less, made for this purpose
Jan 15, 2010. 8:24 PMKnexFreek says:
 Cool!
 5stars
Dec 29, 2009. 5:34 PMCrLz says:
Beautiful wrist watch.
May 16, 2009. 8:23 PMforgetmenot5106 says:
i tried to go to the internetlumber website, but only got a listing of lumber providers, can you give exact web address, i want to get wood samples.
Dec 11, 2009. 7:49 AMsuperdude4agze says:
InternetLumber.com has/had many complaints as scammers against them and have since gone out of business. You will need to source a different lumber supplier.
Aug 20, 2009. 10:11 PMnitrox027 says:
if you have a would burner you should burn 12, 3, 6, and 9 nicly into the wood
Aug 15, 2009. 3:29 PMMikeDoucet says:
I am a wood worker myself and this is nice, great watch great job on the wood. Im gonna do something like this as well... EPIC
Jul 28, 2009. 2:22 AMliljrab says:
Anyway that you could sell me one of these babies?
Jul 23, 2009. 9:33 AMbpantell says:
This is freakin awesome. I'm so going to try this!
Apr 25, 2009. 10:03 PMatrus713 says:
woulnt it be way easier to just buy the veneer?
Jun 18, 2009. 2:25 PMV3ritas says:
I was thinking the same thing. . . could probably get a free sample of some nice veneers somewhere online.
Jul 16, 2009. 3:30 PMnobelium106 says:
veneer is easier, but real good cocobolo blows veneer away, it has this depth to it, (can also check out rosewood, same family)
Feb 27, 2007. 4:28 PMoniony says:
Having just sanded all of the skirting, architrave, picture rails and radiators in our house I just could not face this step. So I am now the proud owner of the world's first wristwatch with a 3cm thick wooden watch face.
Jul 12, 2009. 6:58 AMrayked says:
show me
Jun 10, 2009. 8:50 AMgerry_49 says:
Very nice!
Jun 4, 2009. 8:39 PMtrogabird says:
A flat bottom PVC cap about 1 n in diameter would work good in place of the coke cap. Cut 2 thin wedges to useto help level the other side of the watch band as you remove the pins.
Jun 4, 2009. 8:23 PMtrogabird says:
Sears has a dovetail saw for $9.99 that would be good for trimming wood like this to shape. You can also find many different woods for sale on the internet. do a Google search for exotic woods.
Jun 2, 2009. 6:39 PMfrizle says:
what kind of watch do you have?
1-40 of 138next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
27
Author:jamesv
