Wooden Hand Mirror
Published
Introduction: Wooden Hand Mirror
Come on holiday in South Korea.
I made a gift to the cousin's daughter. It is a wooden hand mirror.
I think she'd love it.
Creation is easy.
Preparation materials
Wood plate - I have a 19 mm plates.
Acrylic mirror - before I bought as a sample.
Tool
CNC - wood processing
Sandpaper-wood trim, trim the acrylic mirror
Program
AutoCAD - drawings
Mastercam - drawing conversion G-code
Mach3 - cnc control
Step 1: AutoCAD
Create drawings using AutoCAD.
For 2D drawing, you can draw the thinking part of the quarried.
The two squares by using the command line.
The edges of the rectangle using the fillet command smooth.
For more information, see the video.
Step 2: Mastercam
Using Master Cam
Autocad files is converted into G-code. Pocket, configuration command was used.
When you use a pocket command, be careful in depth to be machined.
Step 3: Mach3 and CNC Machining
Mach 3 is used to process wood plates.
First of all, clamping the wood plate on the machine.
Open the file in the program.
The end mill is located at the origin of the plate.
Press the start button to activate the machine.
Step 4: Assembly (sanding)
Insert mirror at the pocket of wood
And, hard sanding.
    • Stick It! Contest
      Stick It! Contest
    • Pets Challenge
      Pets Challenge
    2 Comments
