loading
Step 9: Done! enjoy all the extra time with your adoring fans
<p>Also a great source - for just about anything, by the way - <a href="http://www.parts-express.com/cat/latches/654" rel="nofollow">Parts Express has road case hardware.</a></p>
<p><a href="http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Dmi&field-keywords=strap%20Handle" rel="nofollow">You can also find these</a>, most likely, at your local guitar store. (Peavey sells em shrink wrapped on a card - </p>
<p><a href="http://www.tchweb.com/tchstore/category/surface-mount-catches/s0/Surface-Mount-Twist-Latches-and-Strikes.html" rel="nofollow">http://www.tchweb.com/tchstore/category/surface-mount-catches/s0/Surface-Mount-Twist-Latches-and-Strikes.html</a></p><p>If you'd prefer a more &quot;musiciany&quot; solution, the <a href="http://www.diyroadcasesstore.com/categories/Latches/Recessed-Latches/" rel="nofollow">same thing in recessed</a> is what they use on pro road cases. That would require a jigsaw or router though. </p><p>Also, standard pop rivets hold great in wood.<br></p><p><br></p>
nice I'm my one roadie (and i some times work with LOVEBOX) this would be nice
you can get latches that go on trailers and the such
dude, I like this kind of latches a lot for applications like yours - <a rel="nofollow" href="http://www.leevalley.com/hardware/page.aspx?c=2&amp;p=43997&amp;cat=3,41399,41406">http://www.leevalley.com/hardware/page.aspx?c=2&amp;p=43997&amp;cat=3,41399,41406</a> - they're usually very secure. <br/>
yeah, those draw latches are great - probably better than what I used
actually, the ones you used look more secure. i dont trust those draw latches. im afraid they'll open up on their own.
"CBGB"? Is that "Comic Book Guy Bistro"?
nah, it's a famous music venue in New York that shut down in the past few years..
Those draw latches kerns posted are what I used, because they're cheap and work fine. If I was building a tougher case, I'd use some of these <a rel="nofollow" href="http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=262-350">butterfly latches</a> and maybe some <a rel="nofollow" href="http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=262-165">cabinet corners</a>. But for a regular, non-touring pedal case, what you have is fine and pretty similar to mine, except I used <a rel="nofollow" href="http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=262-188">take apart hinges</a> on the back side so all of the weight isn't on the latches. I also added some <a rel="nofollow" href="http://www.partsexpress.com/pe/showdetl.cfm?&Partnumber=260-773">rubber feet</a> on the bottom of mine to keep it from moving about<br/>
that would be so heavy!!!
That's why you have roadies... Weight is good- it lessens the chance of it moving on stage. Mine was too light! And it's not the sort of thing you have to pick up and carry around a lot.
is it meant to insert the electronics of an effect pedal ?If yes you need an iron box , if you use wood it wil broom more and lose quality...
that's not what it is for. you put your pedals on the pedal board to keep them organized
let's see your pedals.
About This Instructable
12,473views
34favorites
License:
Bio: currently a graduate student at the MIT Media Lab
More by davidmerrill:Awesome Sandwich DDR-style musical instrument Indoor Deck
Add instructable to:
