3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Woodpunk Chair
Woodpunk Chair
First of all to give credit where credit is due.  I was searching for steampunk on instructables one day and I came across Jeff-o's lamp and loved the design and the idea of calling it "woodpunk" Visit his stuff. Its awesome!
http://www.instructables.com/member/jeff-o/
I saw http://www.instructables.com/member/kcedgerton/ and liked the idea for wood ball bearings; but I didn't use a lathe because I wanted to make a really big one that could hold my weight. I weigh about 190lbs this week. Next week? Maybe more, Maybe less. :)
This is a Woodpunk chair. I have always loved the Punk Genre(Steampunk/Dieselpunk) and the design style. If you are interested in my approach to the design and wish to learn a little more about my background I'm going to put all that stuff at the end of the instructable. I just don't want to get in the way of your work, you have plenty to do when it comes to building this! I promise it's a lot of fun!!
          I have been racking my brain trying to figure out the best way to help you draw out and make some pretty precise cuts. I think I have come up with some fun and innovative ways to help you do just that.
          Whether you make this on a ShopBot CNC or just in your basement go get a pair of calipers I have a cheap pair of digital calipers that cost me around 10 dollars. Just make sure they go out to at least 3 decimal places, and measure at least 6".
          First let's talk about material. This chair is designed for use with .75" plywood. I would recommend AA which is nice and ready to finish on both sides, or AB which is ready to finish on one side and clean and smooth on the other but not ready to finish. Take your calipers with you when you go shopping; measure the thickness at both ends try to find a sheet of plywood that is consistently between .69" and .72" The closer you get to .75 the tighter the chair will fit together. (.72" will fit snug and you probably won't have to sand too much.) Also make sure the board is nice and flat you can check this by looking down the side of the board if it curves grab another, I got lucky and found a good straight board about six sheets down. The people at the Home improvements stores are pretty understanding and helpful with this.
          I've broken this Instructable up into two parts; Those who choose to make it manually, or those who have a ShopBot CNC machine or have access to one. If you have a ShopBot Read Step one then go skip ahead to step 10.
This instructable is rather simple if you have a ShopBot CNC and a copy of AUTOCAD 2012. But if not you will have to make this the hard way! Hopefully this will show what a powerful tool  a ShopBot could be.
Okay, all you John Henrys out there looking to do it the hard way continue through the scenic route step by step.
Step 1Materials and Tools Needed
Drill press
Electric sander or Right Angle Grinder (for removing excess material for a better fit.
Table Saw
1/4" router bit
3/8" router bit
1/4" Drill Bit
1/2" Pilot point drill bit
Jig Saw
Calipers
Tape Measure
Compass
1/2" dowels
36" wire or string
Router table
Hand Drill
Brad nailer (1.25" brads)
Wood Glue
OR
PRS Standard 96-48-6 ShopBot CNC machine
AutoCAD 2012
Hand Drill
Router Table
Wood Glue
Hardware needed
4  (2" long .5" bolts)
2  (3" long .5" bolts)
12  (.5" washers)
12  (.5" Nuts)
8  (2" long .25" bolts)
4  (3" long .25" bolts)
24  (.25" washers)
12  (.25" wing nuts)
 4   (2" wood screws)
and
(21) 1" oak craft balls
Your choice of casters
11 comments
Mar 19, 2012. 12:37 PMjeff-o says:
Congratulations! Great name, by the way. ;)
Mar 15, 2012. 9:30 PMcarpeductumc says:
Congrat's on the Furniture Challenge runner-up win! We are, as always, so impressed with your skills and gifts, and this chair is a fantastic exemplar! :)
Feb 26, 2012. 1:55 AMpaqrat says:
This is totally awesome!!
Feb 23, 2012. 2:21 PMflyingpuppy says:
How much would you sell one of these for? I don't have the patience to make one, but it's beautiful!
Feb 23, 2012. 6:55 PMrandomray says:
Looks very cool , but really uncomfortable . How is it to set in ?
Feb 23, 2012. 1:12 PMtinker234 says:
wow cool this would be awesome in brass or a paint like brass love the design i think i cold just sketch the sides and try to make a pattern
Feb 23, 2012. 5:46 PMtinker234 says:
i will thanks there is a local one that really good
Feb 23, 2012. 1:14 PMtinker234 says:
amazing sorry this is amazing saw the planes to wrapped up in the details thanks
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:HandyLandy(just photos)
I was a chef for 14 years, Was Gainfully unemployed for a year doing side projects and carpentry work. After a year of me harassing them for a job; I now work for League MFG. Quick Crate North America...
more »
