3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Woodpunk LED Desk Lamp
Step 3Print and Attach the Patterns
  • last photo ←
Once printed out, the patterns may be cut out and glued directly to the wood using spray adhesive.  To make the patterns easily removable later on, let the fresh glue sit for about 30 seconds before sticking the pattern onto the wood.
I had a lot of straps lying around, so I took the opportunity to use them up where possible.
If you plan the layout of the patterns just right, you can lay down half of the required pieces, then stack one piece of wood on top of the other.  Tape the layers together so they won't slide around.
Roughly cut out all the pieces on the scroll saw, and re-tape where necessary to keep the halves firmly attached together.
6 comments
Nov 6, 2010. 1:31 PMAJC894 says:
will rubber cement work
Sep 16, 2010. 9:26 AMcsswimdude says:
would it be possible to get a list of what parts need to be what thickness Thanks
Sep 18, 2010. 7:36 AMKChappers says:
I think the website is playing up as I can't view the file either.
From ½":
1 base
6 toes
1 reflector (1 ring, 2 plain fingers, 1 finger with joint)
2 curved arm segments
3 spacers with drilled hole
2 middle counterweight sections
From 1/4":
4 straight arm segments
2 elbow joints
2 wrist joints
2 shoulders
10 spacers with 1/2" centre hole
2 spacers with 1/4" centre hole
2 counterweight lid/base pieces
Sep 18, 2010. 8:39 PMcsswimdude says:
ya it works for me as well, this is a really neat project it seems to be alot more doable than some projects on here, great work
Sep 18, 2010. 9:07 AMKChappers says:
Works fine now! Wouldn't allow me to select the second picture this morning.
:thumbs up:
Sep 17, 2010. 9:47 AMcsswimdude says:
im not able to see it very well it gets really blurry
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
347
Author:jeff-o
By day, Jeff is an electronics technologist at a large aeronautics corporation. By night, a mad scientist / hacker / artist / industrial designer wannabe!
