3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Woodpunk LED Desk Lamp
Step 4Drill the Holes
Drill the Holes
  • last photo ←
Before cutting out the pieces properly, it's a good idea to drill the holes first.  Why?  Well, in the case of the stacked cuts, this will ensure that the holes are precisely lined up, making assembly easier later on.  It also gives a bit more material to hold onto, when drilling those large diameter holes.
It's easiest to drill all of the same-size holes at once.  I started with the 1/2" holes, since they are the most numerous.  Then I did the other size holes.
Some of the pieces also have internal cuts.  They'll need a pilot hole drilled, through which the scroll saw blade can be fed.  I used the 1/4" drill bit for this.
When drilling, make sure you place a piece of scrap wood below the piece being cut.  This will help prevent "tearout," which could ruin the look of the lamp.
Keep the matching "pairs" together until cutting is complete.
2 comments
Sep 26, 2010. 4:29 PMzmb says:
For me, I used a 2" hole saw to cut the spacer pieces. Much faster than cutting them out with a saw.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
347
Author:jeff-o
By day, Jeff is an electronics technologist at a large aeronautics corporation. By night, a mad scientist / hacker / artist / industrial designer wannabe!
