Step 8Making Wooden Latches
Simple door latches can be made using just two dowels. A 3/4" to 1" dowel is inserted through the door. A 1/4" dowel is drilled into the handle dowels to make the latch. Pic 29 shows the door closed and latched into a groove cut into a block in the door frame.
Pic 29 and Pic 30 shows a spring catch that uses thin oak as a spring. A wooden door knob on one side and a lever on the other activates the latch. I did cheat and use some screws to hold some of the pieces onto a door that was fastened with screws.
comment
Add Comment
Add Comment
