3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Wool Cycling Jersey: Adding a Zipper
Merino wool is an excellent material for cool weather outdoor wear because it is lightweight, moisture-wicking, and still holds its insulating properties when wet. Unlike other wools, Merino isn't "scratchy" on the skin and is relatively hard-wearing if knit properly, withstanding even washing machine treatment.
This Instructable illustrates how to add a 12in zipper to a sweater, useful for regulating your body's temperature when cycling or hiking. A similar zipper sweater from Ibex for example retails for $75-105. I made this one from a thrift store sweater and zipper for less than $10.
Materials
Merino wool mock turtleneck sweater
14 inch garment zipper
matching polyester thread
Look for a slim fit for cycling use. A mock turtleneck isn't necessary, but matches a traditional wool long sleeve jersey.  Even though we're adding a 12 inch zipper, the extra length of 14in is needed for flipping inside-out.
Step 1Mark for Zipper Placement
Lay the sweater out flat on your work surface, right side out. Locate the center of the sternum area by measuring the half distance between the arm pits. Find the center of the collar. Pins help for temporary marking. Using tailor's chalk or a fabric pencil, mark a 12 inch line along the center, down from the collar. Place a pin horizontally at the 12 inch mark as the end of your chalk line may not be clear.
5 comments
Mar 14, 2010. 10:53 AMeecharlie says:
Any chance you could add a closeup of the zipper termination stitching?
Also, supposing one has never sewn a zipper before, what's a zipper foot look like?
Feb 9, 2010. 10:17 AMtroyml says:
 I have a thrift store merino sweater for which this would be an excellent improvement.  Do fabric stores sell the zippers in a variety of colors, or is it dyed or colored some other way?  My sweater is green, not blue.
Feb 8, 2010. 7:47 PMluvit says:
 it would be cool if you would let your chest hairs hang-out.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:dilg
