First released in 1955, the Wooly Willy toy uses a "magic pen" (magnet in a stick) to move a small amount of iron filings around an illustration of a hairless floating head trapped behind a plastic window. You use the pen to draw hair, mustaches, beards, whiskers and eyebrows on Willy. It sounds simple, and truth be told, it is, but as anyone who's familiar with the toy will tell you, it's a surprising amount of fun.
Well, if you thought that the old Willy was good, hold on to your hat, because Wooly Willy just got a whole lot bigger and better! Complete with modern styling, coffee table functionality, cooperative drawing and a super sized drawing surface, this Wooly Willy coffee table is completely one of a kind and totally rad!
Best of all, it's made almost entirely from Ikea parts, so just about anyone with some very basic building know how can make one.
Wally Woo Woo!
Step 1: Materials and Tools
Materials:
- original Wooly Willy toy
- iron filings
- rare earth magnets
- 1/2" thick 19 3/4" square plywood sheet
- 3/4" wooden dowel
- lag bolts
- washers
- white spray paint
- Ikea Lack 21" table
- Ikea Ribba 19 3/4" shadow box frame
- large format Wooly Willy print
- (1) 19 3/4" piece acetate
- (1) 19 3/4" matte board
- table saw
- drill & bits
- exacto knife
- Illustrator
- Photoshop
- scanner
- large format printer
- paper cutter
- wrench
Step 2: Liberate Willy
First, use an exacto knife to liberate the image of Willy from his cardboard and plastic housing.
Step 3: Scan Willy at High Resolution
This is a good thing since all of the files that I could find on Google Image Search weren't larger then a few hundred pixels wide - way to small to generate a nice vector from.
Step 4: Vectorize Willy
Once you've got it looking good, bring it over to Illustrator and do a live trace on it. I chose to do a 5 color comic illustration trace on it. Then, start messing with it some more to clean it up. Use the pathfinder tool to join and simplify the paths so that Willy starts to look like an actual digital illustration with nice smooth edges.
All in all, Willy underwent a pretty extensive face lift that lasted a couple hours. What came out the other end was a near perfectly vectorized willy image capable of being blown up to any size. Many thanks to fungus amungus for all his help in this step of the process.
Save yourself all of this work and simply download one of the vector files provided below.
Wooly Willy.ai(1422x1422) 293 KB
Wooly Willy.eps(1423x1423) 525 KB
Wooly Willy Legacy.eps(1423x1423) 531 KBStep 5: Modify Ribba Frame
Disassemble the Ribba frame and liberate the square spacer that separates the glass from the back by about an 1". It's got to be cut in half for the iron filings to get close enough to be properly affected by the magnetic pen.
Take the spacer over to the table saw and cut it in half, so that you end up with two 1/2" thick squares.
**The first three pictures below show the dis-assembly of a small white Ribba frame, but, rest assured, the process is exactly the same with the big 19" one.**
Step 6: Build the Table
Cut down a piece of plywood to a 19 3/4" square that fits perfectly inside of the Ribba frame.
Next, replace the the double pointed lag bolt like hardware from the Lack table with something that better suits the new tables design - a normal lag bolt and some washers.
Then, drill some countersinks for the lag bolts and washers in the plywood at the four corners. If your plywood sheet is a little too thin to take up all the space created by cutting down the Ribba spacer, you can bulk things up by including the factory made Masonite frame backer in the new stack. I drilled out holes in this too to allow for the top tiny bit of the bolt head that still stuck up over the plywood.
With everything nice and flush, use a ratchet to drive the lag bolts into the Lack table legs and mount them to the masonite & plywood support boards.
Step 7: Get Wooly Printed, Cut Matte & Acetate
Since the iron filings tend to leave a slight mark in their trail, I decided to cover the print with a $2 piece of acetate that I bought at the art store and protect my investment. The acetate is easy to cut to size and leaves Willy completely mark and streak free.
While at the art store, I picked up simple matte board as well to serve as a nice backer for the poster print...a little unnecessary perhaps, but hey, I'm a professional.
Step 8: Assemble Table Pt. 1
The four legs should be bolted on already at this point, so here we go.
Lay down the masonite backer.
Lay down the matte board.
Use some double sided tape or painters tape looped around your finger to lay down the print.
Finally, lay down the acetate.
Step 9: Assemble Table Pt. 2
Finally, drop the spacer, glass, and Ribba frame down onto the table and secure it into place by bending the little tabs on the frame around the plywood backer. Easy!
Step 10: Build "Magic Pen"
Cut down some 3/4" dowel into comfortable pen lengths...8" or so.
Using first a small drill bit, then a larger one, bore out a hole that will accept the rare earth magnets - in my case, 3/8". Slip the rare earth magnets into the hole (polarity doesn't matter, iron filings aren't polarized themselves). The magnets should be just slightly inset of the tip of the dowel so that the softer wood bonks the glass table top, not the hard metal magnet.
Then, using some 120 & 220 grit paper sand down the dowel and paint it white to match the table.
Step 11: Enjoy!
We've been drawing a bunch already and have barely scratched the surface of what's possible...some of our most notable works appear below.
Visit Our Store »
Go Pro Today »
Make sure the glass is safety glass or acrylic glass if children are involved. Also consider attaching the 'pen' to the table with a cord. Nice job otherwise.
My first idea for an improvement would be to have interchangeable pictures so you could swap out Woolly Willy for Hairy Mary or a forest scene with trees with bare branches or...
Or even interchangeable contained units so you could swap out the Woolly Willy for a maze with raised walls and a ball bearing or a small blob of filings or ferro-fluid?
Great idea by the way and great execution.
romantic poems
Also, making multiple magic pens was inspired. The only improvement I can suggest is perhaps adding a drawer underneath to store the pens in when they aren't in use. Otherwise, this is such a brilliant idea! Love it!
However, great 'ible.
All in all, doing it that way might actually even be easier than cutting the spacer in half on the table saw since it's such a thin cut and the material is so delicate.
L
I could surely produce some of those if I were so inclined...
Since Instructables has already been tossing around the idea of "How to Vajazzle" in the forums, Randofo suggested that I work up a Magnetic Vajazzling device so that prospective vajazzlers could mach up their ideas before taking the plunge.
Who's got my vector art?
odd.
L
L
http://smethportpa.org/events/wooly-willy-wonderdaze/
According to this detailed history of Wooly-Willy, the original Wooly-Willy used dust from magnet grinding instead of iron filings.
http://www.smethporthistory.org/smethportspeciality/wollypage.htm
Vince
