Introduction: Bike Repair Stand on Work Bench.
Picture of Bike Repair Stand on Work Bench.
Find a previous Instructable for (Mobile Bike Stand Repair.)
The upper section is used for bench application.
Step 1: Drill Hole Into Wood Bench Top to Tightly Fit 1.5" PVC (use Additional Wood Blocking Below Top If Needed.)
Picture of Drill Hole Into Wood Bench Top to Tightly Fit 1.5" PVC (use Additional Wood Blocking Below Top If Needed.)
Having a wood top helps - drilling hole into top will support this assembly
Step 2: Clamp for Horiz. Bike Member Is From a "Tee"
Picture of Clamp for Horiz. Bike Member Is From a "Tee"
Cut tee in half - hinge one side - use pull clamp to secure bike at other side - place filling (I used rubber sink mat) between bike tube & clamp.  The grey PVC is Electrical conduit  90 deg.
Step 3: Verify Bike Pedal Clearance
Picture of Verify Bike Pedal Clearance
of all base items.  El as shown should be ample (I used 11"-12" center to center of bike rail & base items.)  If needed install a 1.5" PVC nipple extension befor tee.
Step 4: Note Bungy Cord to Secure Front Wheel & Handle Bar.
Picture of Note Bungy Cord to Secure Front Wheel & Handle Bar.
I find stabilizing the front wheel makes working on the bike much easier.
Step 5: This Is Original Mobile Repair Stand
Picture of This Is Original Mobile Repair Stand
note the call out for clamp & ell.
Step 6: This Is Detail on Original Stand
Picture of This Is Detail on Original Stand
Note details on fabrication of clamp & ell.
About This Instructable
25,627views
31favorites
More by tony33770:Caulking In Tight SpacesBicycle Repair Stand #2 (Portable)Bicycle Truing Stand & Dish Tool
Add instructable to:
