3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Work Bench on the Cheap
Step 6Give Your Baby Back
Give Your Baby Back
Now that you have all of your pieces cut and you have pilot holes drilled, putting this together is easier than doing a jigsaw puzzle. Simply make the backs, the sides, hook 'em together, slap the top on and you're done.
Put two of your legs on semi-even ground and run two braces along the top. Screw them in. I just eyeballed it to see if they were close to even. If you want to use a square, go for it.
I also eyeballed the lower shelf. I wanted it to be low enough that I could get some larger tools on it, but high enough that it was relevant and provided some strength. I ended up making the bottom of my brace about 12" off of the ground.
Once you screw it all together, you should have what my daughter called a fence.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:schnaars
