3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Work Light And Cord Reel From PVC Tubing
Step 2Make The Lamp Bases
Make The Lamp Bases
The idea here is to mount the lamp bases on 3/4" plywood and reduce their circumference to fit inside the 3" tubing. You'll need to be careful and cut a hole on the bottom for the wire connectors and a slot in the edge to slide the connector wire from the other lamp base.
This will only work with plastic bases, you can't cut the ceramic ones.
Also, it's easier if you put solder-less connectors on the ends of the wires for hooking them up.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
44
Author:graphicsman(The Toolman Site)
a.k.a. "The Toolman" has been creative and worked with his hands all of his life. He has been employed in a wide variety of industries including a museum, a major power tool manufacturer, a national v...
more »
