3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
START VOTING!
We have 32 prizes, so please vote for more than one winner!
IS THIS A WINNER?
Working Circuit Symbols
Ever struggled to explain the order that components should go in? Need a subtle reminder, for students to follow? Or maybe want to mess around, but don't have a breadboard to play with? These are the thing for you!
You need:
  • Cardboard (I've used recycled packaging)
  • Glue/tape
  • Aluminium kitchen foil
  • Components
  • Thick marker pen
  • Wire
  • Soldering iron
  • Solder
Step 1Prepare the components
The first thing you'll need to do is attach wires to your components. These need to extend the full length of the card piece, plus about 5cm on each side.
15 comments
Feb 26, 2012. 11:31 AMsnateraar says:
You might want to combine it with this.
http://www.thinkgeek.com/gadgets/tools/eb92/
Feb 27, 2012. 6:21 AMsnateraar says:
The description says you can even paint over other dry layers for wire crossings.. I think I will order some as well!
Feb 27, 2012. 5:32 AMmr.incredible says:
Get a cheap snap kit from Harbor Freight. Put the male snap on the bottom side and female snap on the top side. Both snaps on each end so you are not limited to configuration. You can also stack them. For more advanced components, you can have a snap for each lead, just leave enough room between the snaps for the connections. Make a few plain conductor pieces too so you can lay them out in a easy to see schematic style layout. You could do just about any circuit imaginable. transistors, capacitors, resistors, 555 timers, relays, switches... you are only limited by your imagination.
Another idea is to use plastic instead of cardboard. You really only need one side. Packing tape over the circuit on the back would be sufficient to protect it. It will be more durable. I borrowed a screen shot of a good source of cheap plastic material from another instructable. http://www.instructables.com/id/Easy-Faux-Kydex-Knife-Sheaths/
Feb 26, 2012. 1:30 PMTaranach says:
This is a great "poor man's" version of Snap Circuits... I got the basic version for my son but was quickly disappointed by the lack of variation in their kit... have to buy the "upgrades" with more parts to do more stuff. This looks like you could very easily add as many different components as you'd like in whatever quantities.
I think I will look into doing these and see if I can get them all the same size so they are interchangeable Maybe even see if I can get a "common size" shell, to hold the components, made with a 3D printer or laser cutter...
Feb 26, 2012. 7:55 AMlittleberry says:
I really like this idea as a way to teach my son about circuits. If I were to make a set of these, what would be the ideal pieces to have in a set? Thanks!
Feb 26, 2012. 11:10 AMlittleberry says:
That makes sense--I shall meditate on that. I was thinking designing projects based on pieces available versus determining pieces needed for a given project :). I have one other question: where does the battery fit in? I see it in one of the photos but I'm fuzzy as to where it goes. Do you make another "circuit (card)board" or is it added into one of the existing ones of another component? Thanks again!
Feb 26, 2012. 7:53 AMWCEastFZX says:
Hi,
I'm a physics teacher and this looks pretty cool. I was wondering if aluminum tape would work instead of aluminum foil? Thanks for the awesome idea!
Feb 26, 2012. 7:29 AMbillbillt says:
This is a wonderful idea!...
Feb 24, 2012. 12:44 AMomnibot says:
Nice! Add a magnet or two to the back and the whiteboard becomes a teachable breadboard.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:lucylollipop
