Step 8Refilling the can with fluid
iImage Information
Gently pull of the tips on both the full and empty cans. Cut a short section of the tubing you previously cut out of the empty can. Put it over the protruding nozzles (without the tips). It may help to use a lighter to get a tighter fit on it. Making sure that the full can is right side up and both cans are connected to the tube, open the valves by pushing down on both nozzles simultaneously. If you made a good seal in step 6, your can should begin to fill. (Keep in mind that you shouldn’t fill it too much because it would be bad to put too much pressure on the seal.) However, if the bottle wasn’t well sealed you may experience a leak. Try adding another thick layer of glue and repeating this step once the new layer is dry.
