3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Workmate Bike Stand
Workmate Bike Stand
Bike stand built from 1x4, 2x4 and 2x6 construction lumber designed to fit a Workmate. Cost - since I had scrap lumber, about a dollar for a couple of carriage bolts and wing nuts. Took longer to document in SketchUp than to build, but it was good practice for using SketchUp. One advantage of this design is it can be broken down and hung from a nail in the garage for storage.
Don't have a Workmate. Check out http://bluecollarmtb.com/2005/03/02/bike-repair-stand-blue-collar-style/
Step 1Arms
Arms
Cut two pieces of 1x4 24 inches long for the arms.
One arm has two 3/8 dia holes drilled in it 6 1/4 inches from the end and 3/4 inches from the top and bottom.
Use these holes as a guide to drill the upright and other arm after everything is assembled.
Cut two pieces of 2x4 3 1/2 inches long for the spacer blocks.
Screw the arms to the spacer blocks so there's a gap in the arm assembly for the upright to fit through snugly.
6 comments
May 17, 2012. 12:47 PMggarnier says:
I'm not clear on how it connects to the WorkMate - does it get clamped between the two parts of the WM's deck?
Jun 9, 2010. 7:27 PMcoltpython says:
Hell of an idea!, minor variations if need-be, like you could use rigid conduit instead of wood, i think instead of screwing it together, i would use 1/2" holes, top and bottom and send 3/8"X4"? bolts thru, for easy take down and transport. Also at the very end of the top two horizontal boards, put another thru-bolt on the outside of the seat post, once the bike is in place, insert the bolt and tighten down with a wing nut and youre gravy!:)
May 12, 2006. 12:10 PMradiorental says:
If you arent planning on bolting the base down then it needs to extend both to underneath the bike and out to either side. Otherwise this will just topple over as soon as you try to get that ceased cable off, for example. 2nd point, small thing, but the bike's seat post clamp will fudge up using a c-clamp there, but it should bite the frame below no worries.
May 12, 2006. 11:30 AMewilhelm says:
Would you be willing to post your SketchUp files?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:JeffG
