This instructable has been removed by the author.
10
comments
Add Comment
Next time you go to a place where yours is not the basic one, I hope some one dumps in your face and see how you feel.
Been there and done that and when some one rips you, not for your effort, but instead because you don't talk/spell/write their way it not only embarrasses you but makes it so much more likely that you won't venture there again.
A cup or pound of wax, a cup of sawdust, 5 charcoal briquettes, a cup of peanuts and a cup of dryer lint. Ground the charcoal and peanuts up and mix with sawdust. Place the wax in a short/wide sized container that you don't need. Place the container in a pan or pot of boiling water. Reduce to a simmer when the wax melts. Add in the lint, peanuts, charcoal and sawdust and then mix well. Use anything flat or even recycled cups. scoop the mixture and make piles as tall as you want or put the mixture into the cups. allow to cool. It is not necessary to have an external wick or other lighting place if you pile the mixture up. One point or another will be thin enough to use as a starting point. If you use the cups, leave a tiny amount of lint sticking out that you can light. Viola, fire starter...... or are the peanuts just to eat while you're making them?
Otherwise, very good Instructable. It did paint the broad picture and allowed others to use their own form.
But what about the peanuts? You mentioned peanuts but you didn't say in your steps if you must add it in the cup. And is this safe??? Because 'n don't want it to explode or something like that...
