Step 1: Parts
This runs on 230v AC. For 110v AC, change the capacitor values (to 0.47 uF, 250 volts).
Warning: This involves AC Mains ! Do not attempt, unless proficient.
PDF Downloads
As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
1) Which led's you u used?
2) If i keep it whole night how long the led losts?
Provide the diagram of led connection
I hade made one LED lamp where i used 19 led's, if i keep it on for 8 to 10 hrs after a couple of weeks led brightness will go it becomes very dull need to replace the whole led set. Please suggest wat need to be done to keep its brightness for longer time
1) 5 mm white-green leds of 3.2v & 20 millliamp rating - the normal ones.
2) i use it everyday for 8 hours as night light, no damage to led or the lumen.
3) It is so simple, what diagram u require for 4 leds, if u yourself have made a 19 led bulb !!???
Connect a positive leg of one led to a negative leg of another. This is one pair of 2 leds. Make as many pairs as you wish upto 14.
The way forward, without getting into your erroneous bulb, is to discard it altogether and make one like this one (?)
Hope it helps...
reg
ketan
I connected same in series ( connecting +ve leg to -ve even though the same problem need to change led's after 2 weeks of daily 5hrs use. I used 474k-400volts non polarity capacitor and1meg 1/4 watt resistor to drop voltage and 160v 47 uf polarity capicator. i tried by increasing resistor value also but in vain the led lumen will come down and last only for a couple of weeks.
I'm i doing any mistake? can u suggest me in this, i really looking for power efficiency.
An LED, by itself cannot be directly connected to a 110VAC or 220VAC supply. it will burst, doesn't matter if it is designed for 50k or 100k hrs. it is designed to take 3volts only.
You have to understand - the circuit assembly becomes important to get the life it is designed for.
Any capacitor will not do. Any resistor will not do. The specs suggested here are "robust" for the lamp, full stop.
reg
ketan
Why are you using just any capacitor!!???
1. Pl see the capacitor in the pic - the orange one. it is 0.22 uF (micro Faraday, not KF!!!) with 400 volt rating. I think it is made by Phillips company.
capacitor reduces the voltage from 230VAC to below 3V required by the LED. Higher rating will release more current and damage the LEDs.
2. I also dont understand why u use the polarized cap!!
3. Your wattage rating rating of 1/4 for the resistor is also wrong! it should be atleast 1/2 and better still 1k. Else it will give out smoke, burnout and also burn the leds.
You are lucky not to have caused an accident. Pl ensure that your knowledge always surpasses your enthusiasm! ;-D
reg
ketan
__________
"May the good belong to all the people in the world.
May the rulers go by the path of justice.
May the best of men and their source always prove to be a blessing.
May all the world rejoice in happiness.
May rain come in time and plentifulness be on Earth.
May this world be free from suffering and the noble ones be free from fears"
---- Vedic blessing
Thanks for ur input. I Purchased the cap!! i asked for 0.22uf 400v instead he gave me 224 J 400v and said both are same. Is both cap value same can i use it?
reg
ketan
;-D
reg
k10
Open connection are always dangerous, a lizard can short circuit the connections.
Now for the joke ! Think of it as a lizard repellent ! Haha
reg
ketan
