3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
World's Smallest Jacob's Ladder: LOW voltage Climbing arc
World\
Here is possibly a world's first low voltage and World's Smallest Jacob's Ladder.It uses a very low voltage (20V AC) from an old train track transformer. I would have made a 10,000 V one but my parents found the plans so yeah. It starts at a (aprox.) .5 mm and ends at a .5mm gap at most. IF the wires are postioned right it will climb about 1/2 inch at most, most of the time not at all.
The reason why the arc move up (atleast in bigger ladders) is because it heats up the air lowering the resistence in the air.
You will have seen these in scary movies with mad scientists except ours is a little safer, cheaper and on a much smaller scale!
I finally was able to add it at my school here it is:
Also sorry for the last part, it is suppose to read "Make your own at instru..."
This didn'y cost me anything because I had everything just laying around, to buy it all it would cost you $3-$50 depending on how much of the materials you have.
Caution: Electicity at any voltage can be harmful but yet useful, build at your own risk, not mine. Electricity does hurt, i have found that out the hard way. Don't keep running too long otherwise the small transformer will over heat because it is not designed to run something like this!
Step 1The materials
The materials
Here is the list of materials you will need:
Materials
-22 guage wire non insulated (2 paper clips could work)
-Pliers (to adjust wire, not needed)
-Screw Driver (to abjust wire)
-Tape (electrical works best)
-Wire Cutter(optional)
-old train transformer or any transformer that puts out less than 100Volts(could be more but then it wouldn't be low voltage,would it)
First cut the Wire into two 2-4inch pieces with the wire cutter.
After that bend the wire to create little hook to get screwed onto the transformer (as seen in pictures). You will need two of the bent wire thingies.
34 comments
Jun 30, 2009. 7:36 AMtinkerman92 says:
a jacobs ladder is called a jacobs ladder because the arc goes up like a ladder this is just a spark because the arc does not move at all
Nov 28, 2008. 11:19 AMPlasmana says:
Is this really a 20 volt AC arc???
Jun 4, 2009. 12:47 PMbylerfamily says:
Yep.Have you ever noticed the ible on the microwave transformer arc welder?I happen to know that train transformers are high amps.Enough amps that it arcs.The welder is 36v at a ton of amps.And it arcs.(Sound plausible?)
Jun 1, 2009. 6:56 AMAlex McCown says:
looks to me like its just a mini spot weld
Nov 30, 2008. 5:43 PMchriskarr says:
It puts out 9VA, so it's possible for it to sustain an arc, I guess. Arc welders can run at 36 volts when their current is high enough, and their arcs are very high amperage, so they "super-ionize" (I love being a word-smith) the air. The welders have to strike an arc first, so this guy must put a screwdriver in the middle of his 'ladder' to get the arc started. Even if all of the above is true, it's impressive that he even tried, and even more impressive that he achieved success. Most people try to build it bigger, but when you try to build it smaller it gets a lot more difficult.
Dec 2, 2008. 6:39 PMchriskarr says:
Yes, but the transformer says that it's 18VDC/20VAC at 9VA (It says 9VA in the middle of the two voltage ratings). 9VA means nine-volt-amps; that means that, if you take the voltage and multiply it by the amperage, you get 9. So, in your case, you could take the number of volts and divide it by nine (20/9) and get the number of amps, which would be 2.222222222222222(etc.).
Mar 22, 2009. 6:25 PMlegless says:
Simple power is calculated by the formula P=IxE (power=current x voltage) so basically at it's simplest 9VA is saying that it's rated at 9W of power. IN theory DC is "pure" so DC power is given in W (Watts) but AC complicates things due to other factors so VA units are used. However In the real world true AC power is not as straightforward as just "volts x amps" but it's a good quick guide.
Dec 21, 2008. 7:59 AMtriggernum5 says:
You did the math wrong there..
9W = 20Volts*Amps
Amps = 9VA/20V = 0.45A
Ppl who are comparing this to a carbon arc welder are correct.. There is a difference between 'breakdown voltage', and the sustaining voltage of a spark..
The author is correct about the heated air from the short circuit lowering the resistance.. Its actually a negative resistance relationship, so without that transformer limiting to half an amp, that would grow out of control even at lower voltages with unlimited current..
If you're letting the short circuit at the bottom remain after ignition, you're killing your performance since you're limited to 0.5 A..
Break that short circuit after its done its job of heating the bottom enough to lower the breakdown voltage of the air, and more current will be available to pass through the spark gap you've formed, and more heat will be created above the spark due to the cathode fall rather than heating air that doesn't need to be heated anymore.. Thus allowing further separation, and a higher climb..
Most low voltage sparks use a momentary HV spike to breakdown the air so its already ionized and capable of conducting lower voltages.. If you read a bit on inductive kick, or buck-boost converters you'll see how easily this can be done with your current transformer and a coil of wire.. You can easily get that transformer to make HV sparks.. And unless you used them to charge HV capacitors, they would be fun and safe like static electricity.. All in all safer than your current setup which could burn your house down..:)
Your parents are wise to disallow neon sign transformers.. Those are dangerous because they are capable of supplying alot of current at HV where as what I'm describing carries 'very little'..
Look into flyback transformers for a decently safe and fun HV source.. They're much higher voltage than NST's, but supply much less current..
Be careful harvesting flyback's from crt's though.. Like I said, capacitors + HV = BIG THREAT.. There are big caps in a tv/monitor that can remain charged with alot of HV even after its unplugged.. Read up on crt safety/discharging if you decide to upgrade..
Dec 21, 2008. 8:58 AMchriskarr says:
Thank you for clarifying that. I didn't realize my mistake. I admit that I was wrong, this time; however my reasoning was perfectly correct. (By the way, froggyman, did you use a screw-driver to start the arc?)
Dec 21, 2008. 9:39 AMtriggernum5 says:
You weren't wrong, and your reasoning was correct, you just weren't taking full advantage of your setup.. A screw driver could work to initiate the spark, but something that acts less like a heatsink (smaller/thinner metal object) would be better.. Have you tried pencil leads? You could make a nifty small carbon arc..
Dec 21, 2008. 10:59 AMtriggernum5 says:
Electrolysis could be fun with those 18V dc posts, and at that current you can't do too much harm unless you try really hard.. Can bring a whole new meaning to the term 'water bomb'..
Dec 21, 2008. 6:15 PMtriggernum5 says:
You're talking about thermite I think.. Steel wool is a much better means of making iron(III) oxide via electrolysis, but I really can't suggest playing with thermite.. That stuff is DANGEROUS!! I was talking about small HHO explosions.. There are a ton of things you can do with electrolysis.. I used to have a rig that produced pure sodium metal, but I sold it a few years ago.. That was a pretty extreme build compared to simpler things like electroplating, or HHO/Cl2/HCl production.. You can make alot of dangerous chemicals with a transformer..
Dec 21, 2008. 9:43 AMtriggernum5 says:
Oh yea, I guess you were wrong on the math.. I thought that comment was made by somebody else.. Thats an easy mental slip up though..
Nov 30, 2008. 5:54 PMchriskarr says:
P.S. The information I have about the arc welders can be validated with another instructable (even though I don't like advertising). Here it is...The Battery Arc Welder
You can find the voltage info on the third step.
May 3, 2009. 8:56 AMfiremanfu says:
I have the same transformer, anyway I'm going to try this later today.
Feb 8, 2009. 9:17 PMrocketman221 says:
i dont think this is really a jacobs jadder. in the video the arc just stayed in on place. if you swap the wire with pencil lead it would probably make a good carbon arc light though.
Dec 2, 2008. 1:50 PMjunits15 says:
what did your parents say when the found out?
Dec 5, 2008. 1:23 PMjunits15 says:
XD well i i guess thats what parents do, my parent would say the same thing, execpt they wouldn't let me build the plasma speaker
Nov 2, 2008. 6:56 PMguyfrom7up says:
I totally agree you can get an arc at 20 volts ac, but that aint no jacobs ladder in the video. at 20 vac you can only get an arc, but it's not climbing...
Oct 31, 2008. 9:26 AMRob K says:
Don't you need a few 1000 volts to even get a spark and your getting it off of what looks like 20 volts. Are you just frying the wire like if it was carbon rods.
Oct 30, 2008. 3:53 PMBongmaster says:
seems interesting but its lacking in the picture department, how about it working? ;)
Oct 31, 2008. 3:36 PMBongmaster says:
ouch :S dialup is painfull :S
Oct 30, 2008. 7:04 PMguyfrom7up says:
stainless steal in this situation has negliable resistance. Copper wire is the answer, though
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:froggyman
