~ World's Greenest WATER PUMP ~
Step 3Button it up.
Button it up.
The hard part is over.
Now take the fire extinguisher and make a pressure tank out of it. You do that by screwing off the extinguisher handle and stuffing a recycled, deflated 20" bicycle tube inside the tank and then inflate it to about 5psi., that's it.
Next, assemble the pump like you see it in the parts list picture and lash it down to something strong or it will walk all over the woods. (remember that water hammer discussion earlier, well, the hammer part is for real!) so lock it down strongly, I used 4 x 3' fence bars bolted to a board and a 10" concrete block. I strapped the pump to that with copper plumbing straps and stainless screws. The feed water pipe is connected to the pump with a rubber plumbing connector.
4 comments
Jan 29, 2010. 2:39 PMasafche says:
not so green as you can think... the pump actually takes the pressure from, let say "x" of the water, spill that "x" right there, and with that pressure it deliver the "1-x" of the water up for some distance. if you have infinite water, that could be o.k., or if you'd like to irrigate something right were the pump is - but if you short on water- that vary bad for you...
like someone said in one of the first comments - you can escape the second law of thermo that say, basically that energy value in total is always decreasing. think about that. you'll find that it is absolutely true, within every system in nature. so how we humans have so much pretension that we think that we will do better where nature had failed...?
Apr 2, 2010. 7:02 PMcabin_boy says:
I have some questions.  What size fire extinguisher is best?  Does size affect flow of water over distance?  What size bicycle inner tube should be used?  How noisy is this unit?  How does the fire extinguisher attach to the rest of the unit?  Does it run all the time or can I stop and start it at will?
It looks like just the thing i need but I may need to get help building one and I need to be able to thoroughly explain the design.  Thanks.
Apr 19, 2010. 5:31 AMwilmadan says:
i have come up to a solution by putting a diaphram with a  spring  to help in pumping the water. make a hole on top of the tank to install the diaphram.tightly fit the nuts to air tight the tank.
Mar 29, 2009. 9:41 AMGordieGii says:
Hey, could this hammer effect be converted into a pile driver? Just thinking out loud... Gordie.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
22
Author:eltigre
Inventing (and breaking stuff to see how it works) since before the turn of the century...
