Step 3Build a download circuit
iImage Information
This download circuit uses a picaxe chip, a couple of resistors, a regulator and a 9V battery. More information is available in the picaxe documentation/help which comes up in the help menu of the program. The circuit should only take a few minutes to build once all the parts are to hand. Once a chip is programmed it retains its program in EEPROM even when the power is turned off. Since we are programming two chips it might be worth labeling the chips so you know which is which. You can always go back and reprogram a chip by removing a link and moving a resistor.
I might also add that picaxes do run happily on 3 AA batteries. A 5V regulated supply is useful for running analog inputs as the reference voltages don't change, but for simple on/off circuits a regulated supply is not needed. The 5V reg can be left out in these situations.
