3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Worldwide microcontroller link for under $20
Step 8Add some code
Add some code
See step 12 of the other instructable for the location of the button that flips between form view and code view. Switch to code view and paste the following code in. The colors should all reappear as in the screenshot . If a line hasn't copied properly due to a wordwrap problem then delete spaces till the error message goes away. I've tried to comment most of the lines so the code at least makes some sense. Delete the public class bit so the text is blank before pasting this - this code already has a public class. If an object like a text box hasn't been placed on the form or has the wrong name then it will come up in the text code with a squiggly blue line under it.
Imports System.IO
Imports Strings = Microsoft.VisualBasic ' so can use things like left( and right( for strings
Public Class Form1
Public Declare Sub Sleep Lib "kernel32" (ByVal dwMilliseconds As Integer) ' for sleep statements
Dim WithEvents serialPort As New IO.Ports.SerialPort ' serial port declare
Dim PicaxeRegisters(0 To 13) As Byte ' registers b0 to b13
Dim ModifyFlag As Boolean
Private Sub Form1_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load ' need all this rubbish stuff - .net puts it in automatically when go form1events above/load
Timer1.Enabled = True ' put this in code as defaults to false when created
Timer1.Interval = 20000 ' every 20 seconds
PictureBox1.BackColor = Color.Gray ' start with the comms boxes gray
PictureBox2.BackColor = Color.Gray
ModifyFlag = False ' if modify a value manually then skip download
RichTextBox1.Multiline = True ' so can display more than one line
Call DisplayPicaxeRegisters() ' display the 14 registers
Call ReadFTPFilename() ' read the filename off the disk (resaved every 20 secs)
End Sub
Sub SerialTxRx()
Dim DataPacket(0 To 17) As Byte ' entire data packet "Data"+14 bytes
Dim i As Integer ' i is always useful for loops etc
For i = 0 To 3
DataPacket(i) = Asc(Mid("Data", i + 1, 1)) ' add the word "Data" to the packet
Next
For i = 0 To 13
DataPacket(i + 4) = PicaxeRegisters(i) ' add all the bytes to the packet
Next
If serialPort.IsOpen Then
serialPort.Close() ' just in case already opened
End If
Try
With serialPort
.PortName = "COM1" ' Most new computers default to com1 but any pre 1999 computer with a serial mouse will probably default to com2
.BaudRate = 2400 ' 2400 is the maxiumum speed for small picaxes
.Parity = IO.Ports.Parity.None ' no parity
.DataBits = 8 ' 8 bits
.StopBits = IO.Ports.StopBits.One ' one stop bit
.ReadTimeout = 1000 ' milliseconds so times out in 1 second if no response
.Open() ' open the serial port
.DiscardInBuffer() ' clear the input buffer
.Write(DataPacket, 0, 18) ' send the datapacket array
Call Sleep(300) ' 100 milliseconds minimum to wait for data to come back and more if data stream is longer
.Read(DataPacket, 0, 18) ' read back in the data packet array
.Close() ' close the serial port
End With
For i = 4 To 17
PicaxeRegisters(i - 4) = DataPacket(i) ' move the new data packet into the register array
Next
PictureBox1.BackColor = Color.GreenYellow ' working
Catch ex As Exception
PictureBox1.BackColor = Color.Red ' not working
End Try
End Sub
Sub FTPUpload(ByVal Filename As String)
Dim localFile As String 'place to store data
Dim remoteFile As String ' filename is case sensitive this is really important
Const host As String = "ftp://ftp.0catch.com" ' note the 0 is a zero not a character O
Const username As String = "picaxe.0catch.com"
Const password As String = "picaxetester"
Dim URI As String
localFile = Filename ' maybe not needed but if define a location eg c:\mydirectory can add easily this way
remoteFile = "/" + Filename ' file on ftp server needs "/" added in front
URI = host + remoteFile
Try
Dim ftp As System.Net.FtpWebRequest = CType(System.Net.FtpWebRequest.Create(URI), System.Net.FtpWebRequest)
ftp.Credentials = New System.Net.NetworkCredential(username, password) ' log in
ftp.KeepAlive = False ' will be disconnecting once done
ftp.UseBinary = True ' use binary comms
ftp.Timeout = 9000 ' timeout after 9 seconds - very useful as ftp sometimes dies
'timeout (and the clock frequency of 20 secs) may need to be slower for dialup connections
ftp.Method = System.Net.WebRequestMethods.Ftp.UploadFile ' start sending file
Dim fs As New FileStream(localFile, FileMode.Open) ' open local file
Dim filecontents(fs.Length) As Byte ' read into memory
fs.Read(filecontents, 0, fs.Length)
fs.Close() ' close the file
Dim requestStream As Stream = ftp.GetRequestStream() ' start ftp link
requestStream.Write(filecontents, 0, filecontents.Length) ' send it
requestStream.Close() ' close the link
PictureBox2.BackColor = Color.GreenYellow ' change the box to green to say worked ok
Label2.Text = "FTP Connected" ' text saying it connected
Catch 'can't connect
PictureBox2.BackColor = Color.Red ' box to red as no connection
Label2.Text = "FTP Upload Fail" ' text saying connection failed
End Try
End Sub
Sub FTPDownload(ByVal Filename As String)
' downloads remotefile to localfile
Dim URI As String
'localFile = "C:\" + Filename ' store in root directory but can change this
localFile = Filename ' so can add c:\ if need to define actual location
remoteFile = "/" + Filename ' added to remote ftp location
URI = host + remoteFile ' make up full address
Try
ftp.KeepAlive = False ' will be disconnecting after finished
ftp.UseBinary = True ' binary mode
ftp.Method = System.Net.WebRequestMethods.Ftp.DownloadFile ' download a file
' read in pieces as don't know how big the file is
Using response As System.Net.FtpWebResponse = CType(ftp.GetResponse, System.Net.FtpWebResponse)
Using responseStream As IO.Stream = response.GetResponseStream
Using fs As New IO.FileStream(localFile, IO.FileMode.Create)
Dim buffer(2047) As Byte
Dim read As Integer = 0
Do
read = responseStream.Read(buffer, 0, buffer.Length) ' piece from ftp
fs.Write(buffer, 0, read) ' and write to file
Loop Until read = 0 ' until no more pieces
responseStream.Close() ' close the ftp file
fs.Flush() ' flush clear
fs.Close() ' and close the file
End Using
responseStream.Close() ' close it even if nothing was there
End Using
response.Close()
PictureBox2.BackColor = Color.GreenYellow ' green box as it worked
Label2.Text = "FTP Connected" ' and text saying it worked
End Using
Catch ' put error codes here
PictureBox2.BackColor = Color.Red ' red box as it didn't work
Label2.Text = "FTP Download Fail" ' and message to say this
End Try
End Sub
Private Sub Timer1_Tick(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Timer1.Tick
If ModifyFlag = False Then 'if user changed a byte then don't download
Label3.Text = "Downloading"
System.Windows.Forms.Application.DoEvents() ' so new label text displays
Call FTPDownload(TextBox3.Text) ' download remote file
Label3.Text = "Downloaded"
Call ReadRemoteFileToRegisters() ' save file numbers to the register array
Label3.Text = "Talking to picaxe"
Else
ModifyFlag = False 'reset the flag
End If
Call SerialTxRx() ' send to the picaxe and read it back
Label3.Text = "Sent and recieved from picaxe"
Call SaveRegistersToLocalFile() ' save numbers to file
Label3.Text = "Uploading"
Call FTPUpload(TextBox3.Text) ' send back up to ftp site named as my name
Label3.Text = "Resting"
Call SaveFTPFilename() ' so reads in when restart
End Sub
Sub DisplayPicaxeRegisters()
Dim i As Integer
Dim registernumber As String
RichTextBox1.Multiline = True ' so can display more than one line in the text box
RichTextBox1.Clear() ' clear the text box
For i = 0 To 13
registernumber = Trim(Str(i)) ' trim off leading spaces
If i < 10 Then
registernumber = "0" + registernumber ' add 0 to numbers under 10
End If
RichTextBox1.AppendText(registernumber + " = " + Str(PicaxeRegisters(i)) + Chr(13))
Next ' chr(13) is carriage return so new line
End Sub
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
Dim i As Integer
' check out of range first
i = Val(TextBox1.Text)
If i < 0 Or i > 13 Then
TextBox1.Text = 0
End If
i = Val(TextBox2.Text)
If i < 0 Or i > 255 Then
TextBox2.Text = 0
End If
PicaxeRegisters(Val(TextBox1.Text)) = Val(TextBox2.Text) ' change the value
Call DisplayPicaxeRegisters() ' and refresh the display
ModifyFlag = True ' and next ftp link skip downloading
End Sub
Sub SaveRegistersToLocalFile() ' save register array in a local text file
Dim i As Integer
FileOpen(1, TextBox3.Text, OpenMode.Output) ' open the text file named in the text box
For i = 0 To 13
PrintLine(1, Str(PicaxeRegisters(i))) ' save 14 values
Next
FileClose(1) ' close the file
End Sub
Sub ReadRemoteFileToRegisters() ' read local text file into the register array
Dim i As Integer
Dim LineOfText As String
Try
FileOpen(1, TextBox3.Text, OpenMode.Input) ' read the remote file name
For i = 0 To 13
LineOfText = LineInput(1) ' read in the 14 lines
PicaxeRegisters(i) = Val(LineOfText) ' convert text to values
Next
FileClose(1)
FileClose(1) ' file doesn't exist so do nothing
End Try
End Sub
Sub ReadFTPFilename() ' so the name of the remote ftp file is the same next time this program is run
Try
FileOpen(1, "FTPFilename.txt", OpenMode.Input) ' open the file
TextBox3.Text = LineOfText ' read the name
FileClose(1)
FileClose(1)
End Try
End Sub
Sub SaveFTPFilename()
FileOpen(1, "FTPFilename.txt", OpenMode.Output) ' save the remote ftp file name
PrintLine(1, TextBox3.Text)
FileClose(1)
End Sub
End Class
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
29
Author:Dr_Acula
