3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Worm Condo Composter
Step 4Setting up the condo
The untouched bin goes in the bottom. Put the small plastic containers in the corners to act as risers. Stackable containers don't allow for much room between bins when they're stacked one inside the other. Also, worm bins do generate liquids and if you give it melon rinds and ignore it, it can generate a lot of liquid!
Place your first full bin on the risers and add your worms. If you put a lid on it, your worms are less likely to escape. As you fill bins, add them to the stack. Need compost or run out of bins? Take a look in the bottom bin. It should be compost and ready to reuse. If you're just setting up and the bottom bin is still scraps, you'll need to acquire and perforate more bins. An established worm colony can eat through my garbage in under a month. I've heard it can take about 3 months to establish a colony.
7 comments
Oct 14, 2011. 9:52 PMrichiebleu says:
If we are composting outside, would it be fine to have a tray just collect the drippings or is there some benefit for the worms to have a bottom bin that has no holes.
Dec 20, 2009. 5:12 PMmarinekid says:
How do the worms get from the bottom to the top? They can't fly (can they?? jks).
Nov 12, 2009. 2:20 PMPizzapie500 says:
So the middle bin you put newspaper (can i put packing paper??) the top bin u put food and the bottom one is sewage? On a utube video i saw that they used two bins, same way you did it except 1 bin carried the newspaper, also can u use cardboard?
Jul 18, 2009. 8:36 PMcinderbelle says:
I have a question for you. What do you do with the bins that have been eaten through by the worms? Is there any way to clean them out and reuse them versus buying more bins? I'm also curious as to how long this method of worm composting has worked for you. Are all the castings and liquid found in the bottom bin with the risers?
Jul 19, 2009. 3:19 PMcinderbelle says:
Thank you! That clears it up for me.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:marmandec
