Worm Farm - High Rise
Join Instructables ( Free) and you can view this instructable on one page.
Make sure you check out my other worm farm with volume!
The High rise Worm farm
There are three parts to a worm farm,
1 The basement sewer, (that we love to empty for our plants delight)
2 The middle floor bedroom (we sleep too you know)
3 The top floor dining room (food has to be involved)
In this high rise farm the different rooms are separated by individual containers, this is not always the case as you will see from other worm farm in-structables, but is by far the easiest to do the house keeping on.
The Worm farm in this in-structable, was constructed from Polystyrene boxes of the type commonly seen in the back yard of butchers, grocerys and fish shops in New Zealand and Australia.
Step 1What you Need
What you will need;
Minimum of three polystyrene boxes, (in my case they measure 100cm x 60cm x 60cm with 2cm thick walls with lids and a bead running around the top of the box which meshes with the lids)
-A plastic tap with washer and nut
(Or some means for controlling and dispensing the contents of the basement box) of the
-A cutter of some description
(For cutting the boxes)
-A drill and drill bit to match the external diameter of your tap barrel.
-Bricks or wooden blocks the width of the containers
(Producing sufficient height when stacked to get a bucket under the tap.)
-Two halve bricks or stones
(Extra for weight)
-Marker pen
-Bedding material
(Shredded white paper, light cardboard or coconut fibre)
-Food scrapes
-Extra stability (optional)
10 comments
Jul 31, 2009. 5:25 PMmaireid says:
We have a commercially built worm farm. We got it just two months ago, and the worms are thriving. It is round, and has 4 levels, sitting on legs. We are only using 3 levels at this stage. They say it will take a year for the 1000 worms to multiply before we'll need the 4th level. We plan on using the castings in the garden beds next season (see instructable post on Wicking Beds ). I have a friend who turned me on to the worm farm idea. She's had one for 12 years, and she says the 'worm juice' is a potent fertilizer. She recommends using it right away, diluted with water. Because it is very potent, it will go a long way. At this stage in my learning curve on taking care of them, I blend the veggie cuttings before serving it to them. My friend says I'm spoiling them, but to me it seems more efficient for them to get to the food.
Jul 31, 2009. 10:13 PMmaireid says:
I'm in Melbourne, Australia - out on the N.E. edge.
Nice to have your confirmation on my preferred way of feeding the worms.
The booklet gives a recipe for fattening the worms. If you want it I'll type it out for you. Let me know.
We intend putting worms in the wicking bed soil when the numbers are higher.
The 'official' name for the system is wicking worm beds.
Here is the link: http://www.instructables.com/id/Wicking-Beds/
Cheers!
Maireid
Jun 9, 2009. 12:22 AMstrmrnnr says:
Do you know if the worm pee produced has a shalf life? What happens to it if it is stored in a sealed jug?
Sep 6, 2008. 3:06 PMbedeboop says:
Would you use the casts for your yard?? The soil I mean?
Sep 7, 2008. 6:07 AMbedeboop says:
My yard is about 1/2 an acre....would it be worthwhile??? Thanks!:)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
20
Author:agatornz
