Make sure you check out my other worm farm with volume!
The High rise Worm farm
There are three parts to a worm farm,
1 The basement sewer, (that we love to empty for our plants delight)
2 The middle floor bedroom (we sleep too you know)
3 The top floor dining room (food has to be involved)
In this high rise farm the different rooms are separated by individual containers, this is not always the case as you will see from other worm farm in-structables, but is by far the easiest to do the house keeping on.
The Worm farm in this in-structable, was constructed from Polystyrene boxes of the type commonly seen in the back yard of butchers, grocerys and fish shops in New Zealand and Australia.
Remove these ads by
Signing UpStep 1What you Need
Minimum of three polystyrene boxes, (in my case they measure 100cm x 60cm x 60cm with 2cm thick walls with lids and a bead running around the top of the box which meshes with the lids)
-A plastic tap with washer and nut
(Or some means for controlling and dispensing the contents of the basement box) of the
-A cutter of some description
(For cutting the boxes)
-A drill and drill bit to match the external diameter of your tap barrel.
-Bricks or wooden blocks the width of the containers
(Producing sufficient height when stacked to get a bucket under the tap.)
-Two halve bricks or stones
(Extra for weight)
-Marker pen
-Bedding material
(Shredded white paper, light cardboard or coconut fibre)
-Food scrapes
-Extra stability (optional)
Good to get your feed back! :-)
yes the commercial bins are excellent particular for indoors and for starting off, they do have their limitations however too - the key to worm farms pretty much is:the more space = the more food = the more worms = the faster there is a useful outcome. hence the reason I have since gone to bath tub worm farms ( check out my post on that subject - or search my user name )
i give my worms away to beginners all the time and it only takes a very short time to return the numbers to normal.. like men if they are well feed they are happy and in the case of worms the population thrives.
you can tell your friend that you are doing the right thing when it comes to "spoiling" your worms... because worms don't actually eat the raw vege scraps that you put in there they wait for the microbes and bacteria also in there to convert it all in to liquid.. so in a small worm farm like you have that activity is going to be small and slow.. so you are jumping a step and speeding things up significantly .
yes the worm water is great... i have heard of people watering it down., personally i don't from my bath farm... but yes use it fresh.
what part of the world are you in >
cheers will
New Zealand
Nice to have your confirmation on my preferred way of feeding the worms.
The booklet gives a recipe for fattening the worms. If you want it I'll type it out for you. Let me know.
We intend putting worms in the wicking bed soil when the numbers are higher.
The 'official' name for the system is wicking worm beds.
Here is the link: http://www.instructables.com/id/Wicking-Beds/
Cheers!
Maireid
